Fuel needle problems
Old Mar 24, 2011 | 06:59 PM
rmdl51's Avatar
White_Shadow
Hello, I recently been having problems with my fuel needle, when I fill up tank the needle goes up normally but once I reach 1/4 left of the tank the needle drop below empty and sometimes is just moving a little above or below E but I know that's not being accurate, what could cause this? and how can be fixed?
One more thing as a reference, I have noticed I have a fuel leak when I fill up gas there is a little dripping from somewhere (I have not been able to spot where exactly) behind the rear driver wheel, it's just a few drops and then stops, this happens only when I fill it up maybe 3/4 or full. I don't know if this has something to do with the needle or not, but just mentioned as a reference.
Thank you.
Old Mar 24, 2011 | 07:14 PM
jbbons25's Avatar
For the inaccurate fuel reading, I had that same issue almost a year ago. Change the fuel sender unit that's in the fuel tank. http://forums.maxima.org/7491193-post611.html
As for the fuel leak, I forget which hose, but either the main hose or the vent hose from the filler neck to the tank is cracked so it needs to be changed.
captchaos
Mar 15, 2016 12:18 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
conansriver
Sep 11, 2015 10:26 AM
