MISFIRE only when AC is on
Old May 9, 2011 | 02:25 PM
majordan's Avatar
I have a misfire only when the AC is on and the car is at idle. There is a slight stumble on take-off but other than that she runs great. Any solutions to this problem?
thanks,
Old May 9, 2011 | 03:12 PM
elusivemax93's Avatar
Check spark plugs then wires and/or coil on plugs and all that is fine could be fuel injectors or a vacuum leak
Old May 9, 2011 | 03:50 PM
Dhunterx's Avatar
Does it do it only when you have the a/c on at idle, or just at idle period? Could be some timing issues. You could also try adjusting the AAC valve; it's got a little rubber piece that comes off and you can adjust it with a screwdriver to help with your idle. If it starts misfiring whether you have the a/c on or not, it could very well be an injector on it's way out. The death of these injectors are intermediate; they'll keep kicking on and off until eventually they just die.
Old May 10, 2011 | 07:56 AM
majordan's Avatar
Yes it only misfires when the AC is on and the car is at idle i.e stop lights, sitting in traffic.
Fuel injectors are new (OEM). I will check the plugs, wires and vacuum lines
thanks
Old May 10, 2011 | 08:42 AM
Dhunterx's Avatar
Forgot to ask, do you have a VG or VE? If it's a VG, after checking your plugs, wires, vacuum, ect, try adjusting the AAC valve. Just have the car idling with the a/c on and adjust the valve until the idle stabilizes.
Old May 11, 2011 | 07:11 AM
majordan's Avatar
Yes its a VG,
Thanks for the information, is there any particular direction I need to turn the adjusting screw?
Old May 11, 2011 | 11:25 AM
Dhunterx's Avatar
Just try adjusting the screw when you have the car idling and the a/c on. Just turn either direction until the idle starts to stabilize.
Old May 11, 2011 | 12:19 PM
James92SE's Avatar
2 VE's are better than one!
Are you sure it's even a misfire as opposed to just increased vibration when the compressor is engaged and idle bumped with it?
Old May 14, 2011 | 03:44 PM
majordan's Avatar
Yes,
I am sure, it has a distinct misfire when the AC is set to on.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
