Spongey Brakes even after bleeding
Old May 16, 2011 | 10:00 AM
wcpierson's Avatar
My brake pedal is still spongey after bleeding. Whats next? replace the master cylinder? If so is it incredibly difficult?
Old May 16, 2011 | 02:29 PM
BenStoked's Avatar
Jesus was a Zombie.
spongey brakes is air still in the system.
did you have a helper bleed? if so, who did what?
Old May 16, 2011 | 02:40 PM
khemraj1999's Avatar
if you are doing it yourself..you should get this little tool
http://www.autobarn.net/xxxw-kd-2538.html
Old May 16, 2011 | 04:06 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
did you open the system (ie replacing calipers)? if so maybe you pulled a Redmaxpa007 and put the calipers on the wrong side of the car so that the bleeders are in the wrong spot on the caliper
Old May 16, 2011 | 05:53 PM
CMax03's Avatar
Bleed them again either with help or using a one man bleeding tool......
Old May 16, 2011 | 08:29 PM
wcpierson's Avatar
A friend of mine was helping but Ill take your suggestions and Ill do it again
Old May 17, 2011 | 01:48 PM
nc90gxe's Avatar
I used gravity bleeding and a light tap with the hammer on the calipers with mine (4 wheel disc, non-abs) and had wonderful results. I have a suburban I want to try the same method with (abs equipped) and see if it works. Of course I will do my research before hand.
Old May 18, 2011 | 02:41 PM
Maxkiller's Avatar
Spongey brakes can be master cylinder but it can also be jammed or seized callers, slides, pins, worn discs over minimum rotors. Best bet is to check it all, starting with the easiest bit eg pads. If it comes to being the booster and master cylinder, they are usually the last thing to go. Also check brake linrd
Maxkiller's Avatar
Spongey brakes can be master cylinder but it can also be jammed or seized callers, slides, pins, worn discs over minimum rotors. Best bet is to check it all, starting with the easiest bit eg pads. If it comes to being the booster and master cylinder, they are usually the last thing to go. Also check brake lines for cracking, leaking etc, esp if the pedal goes almost to the floor when you push hard on it.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
