Corner light rewire question
Old Dec 26, 2001 | 08:41 PM
Mike92GXE's Avatar
I did the corner light rewire so that they are always bright and for some reason the are no longer bright. They dont even get brighter when i hit the turn signal. Anyone else had this problem? Should replacing the bulbs solve the problem or will they do the same thing.
Old Dec 26, 2001 | 09:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Corner light rewire question
check all the wirirng...my corner rewire "went bad" after I put my clear corners in, apparently a wire came a loose! so check that....
Old Dec 27, 2001 | 04:17 PM
Mike92GXE's Avatar
i appreciate it da-max, i'll check that out.
Old Dec 28, 2001 | 12:56 AM
Mike92GXE's Avatar
I check my wiring and it was fine the "bright" filament on my bulbs burned out. Has anyone else had this problem? Were they cheap bulbs or what. Any one with this mod, what kind of bulbs do you use and how long do they last?
Old Dec 28, 2001 | 12:53 PM
SuDZ's Avatar
What kind did you have on there?
SuDZ
Old Dec 28, 2001 | 02:36 PM
Mike92GXE's Avatar
Some kind of hyperwhite bulbs. The box was totally in asian writing. I got them from a place called carboys. A performance shop.
Old Dec 28, 2001 | 02:41 PM
Mike92GXE's Avatar
Old Dec 28, 2001 | 03:26 PM
DA-MAX's Avatar
maybe they are too high wattage??? was the wiring harness burned at all??
Old Dec 28, 2001 | 05:24 PM
Mike92GXE's Avatar
The wiring harness wasn't fried. You know how that bulb is a dual filament, The high wattage filament was burnt out but the low wattage filament was fine. I don't know what the deal is. Da-Max, what kind of bulbs do you use and have they ever burnt out after a few months in the corner lamp?
Old Dec 28, 2001 | 06:56 PM
DA-MAX's Avatar
I have the stock watt bulbs in there now, 21/5 watts, but I've had superwhites in there before and everything worked out fine, not sure of their wattage though. I just ordered some superwhite 1157s though...they are 27/8 watts, so hopefully I won't run into any probs......
Old Dec 29, 2001 | 08:18 AM
ninezero's Avatar
i had the same problem i put in 21/5 cause i can,t get here the 27/8
what i finally did was solderin a smal piece of copper wires
over the dual contacts of the bulb and now i have constanly 26 W and this works oke
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
Blackwind
Aug 5, 2015 06:35 PM
