Engine Light On.....
Old Jul 2, 2011 | 06:22 PM
ujm's Avatar
ujm
First real run issue with the good old Maxima.
Engine light came on, car is running rough - Light came on when the car was started, was fine the day before.
The it went out, went a few weeks without any issues -
One again, off again -
Now, it's been on for a few days, thinking about heading to Advance Auto and have them read the codes - I hope that is possible on these cars.
Needs an oil change, don't think that will fix this issue. I'm thinking about checking the ignition first - then injectors........
Hope it is something simple (inexpensive).
Recent (within 10K miles) tune up, fuel filter, air filter, etc. It's a 94 GXE.
Work commute is 80 miles a day, 5 days a week, it's been a great car, hope to keep it that way.
Old Jul 2, 2011 | 06:38 PM
James92SE's Avatar
2 VE's are better than one!
Generally, an actual check engine light on the 3rd gen is commonly an 02 sensor issue. Though I think I've read over the years on VG's that CEL's sometimes accompanied injector issues. I've never had a CEL in my VE with a bad/dead injector, though.
Autozone won't be able to read your codes because you're not OBDII.
You can pull your own codes, though:
http://forums.maxima.org/4873104-post18.html
chrome91's Avatar
could be a injector or oxygen sensor, to read codes you need to do the flash thing, no OBD hookups.
EDIT FUUUUUuuuuuuuuuuuuuuuuu NINJA POSTER
Old Jul 2, 2011 | 07:02 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
pull your codes. report back.
the 3 double-flash is "mode 3"
then when you turn back to the left in mode 3, the reds are the 10's, greens are 1's. So mine was 5 red, 5 green, or 55.
Old Jul 3, 2011 | 10:47 AM
ujm's Avatar
ujm
Of course the engine check light is not on now, can I/should I check for codes (memory?)?
Forgot to mention, I broke my ignition key off in the driver door lock.
I work in Kansas City.
My wife was in Maryville at the time, an hour north of where we live.
Where I work in KC is about 45 minutes south of home.
She brought me the extra key.......
CorollaULEV
30
Aug 9, 2021 08:11 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
