I accidentally...
Old Nov 15, 2011 | 07:01 AM
  #121
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by max_overdrive
this is unrelated but how good it the interior room in a z31 compared to a maxima(driver seat)? i have always wanted one but havent had a chance to sit in one. i ask because im a tall fat guy and leg/head room is important. i have the seat all the way back in my maxima (3rd gen) and its about perfect.
there's a tall fat guy at work with a z31.... shall i forward your query on to him?
i dunno, i'm 5'10" 175lb so i fit in it quite well. tho even at 255lb last summer i never really felt cramped as long as i eased up on the bolsters some.
Old Nov 15, 2011 | 08:40 AM
  #122
James92SE's Avatar
2 VE's are better than one!
Wow you lost 80 lbs in a year?
Old Nov 15, 2011 | 11:09 AM
  #123
max_overdrive's Avatar
ok thanks, my junkyard has one and i keep forgetting to sit in it, i did sit in a z32 and i fit ok .
Old Nov 16, 2011 | 09:04 AM
  #124
90lb in 10 monhts, held steady for 3 months then gained 10lb back. diet only (no exercise, no surgery, no pills)
Old Nov 17, 2011 | 08:25 AM
  #125
zcarmaniac's Avatar
The Z31 is probably more spacious than a Maxima.I sold mine to a guy that was 6'6".
Old Nov 17, 2011 | 06:08 PM
  #126
James92SE's Avatar
Kudos, pretty impressive man
Old Nov 17, 2011 | 09:57 PM
  #127
zcarmaniac's Avatar
Sounds kind of unhealthy.What did you eat?
Old Nov 18, 2011 | 08:13 AM
  #128
lean cuisine, yogurt, fruit, walnuts, water.. wasn't starving by any means, still having right around 2000 cal per day. my "natural" weight is right around 180.. i had just been stuffing my face with so much garbage (6000 calories a day or so, mostly greasy sugary salty stuff) that i gained over 90lb in 3 years from 162lb to 255lb so cutting the crap out allowed me to quickly return to where i was before.
Old Nov 18, 2011 | 08:25 AM
  #129
zcarmaniac's Avatar
I've been working out,eating nutritiously,and several rounds of chemo,and I've only lost 30lbs.I guess I need to hang with you...
Old Nov 18, 2011 | 05:02 PM
  #130
so i got genuine OEM trans mounts and put them on today... was still rough but not AS rough..
but then after the car warmed up as if by the flick of a switch it got MUCH smoother.. so i'm guessing either i have something causing a misfire specifically under open-loop conditions, or an intermittent miss that just so happened to fix itself around the time the engine warmed up.
Old Nov 21, 2011 | 10:06 AM
  #131
blarg.
so everything is back together now (minus the cotter pins in the axle nuts), and magically i also noticed that my left blinker is stuck solid-on, and my right blinker goes into hyperdrive when i try to use it (while my left one is still on).... unfunny car, unfunny.
Old Nov 21, 2011 | 01:48 PM
  #132
Augustus Maximus's Avatar
blarg.
Headlight switch.
Old Nov 25, 2011 | 11:47 PM
  #133
also have cylinder 1 misfire
I guess i gotta take the intake apart and figure out wtf is up with that injector... i ohmed it when i had the intake manifold off last month and they were all fine....
i was *attempting* to swap the 89-92 middle intake plate for a 93-94 plate (only difference is that it's notched to make room for the bigger injector plugs) but i accidentally grabbed my extra 89-92 plate, not my 93-94 plate. I've since found the correct plate in a box in the garage so i gotta do it alll over again
Originally Posted by Augustus Maximus
Headlight switch.
eh... i doubt it.. i combed through the FSM and based on how the car is wired, it's most likely the combo flasher unit. There's 2 different signal systems... one for the 89-91 cars, and a different one for the 92-94 cars. But on either system it would be electrically impossible for the headlight switch to make a signal bulb stay solid-on
The 89-91 cars use an indirect system with a 7-pin combo flasher so that the signal trigger and corner-lamp trigger share the same wire. The signal switch doesn't directly handle the bulb circuit, it only grounds the trigger wires from the combo flasher and corner lamp units.
89-91 combo flasher wires:
  • R/G power (from battery or IGN via hazard switch, depending if it's pressed)
  • R/L left trigger wire (to turn signal switch pin 3, grounded thru pin 1 when active)
  • R Right trigger wire (to turn signal switch 2, grounded thru pin 1 when active)
  • P/B left flashing output
  • P/L right flashing output
  • B ground
  • P trigger from hazard-on
So odds are it's flaky capacitors/transistors or bad solders inside this unit that are causing the left side the right side to flash fast. nc90gxe said it had happened to him a time or two when he owned the car so i guess it's just being a little biitch again
The 92-94 cars use a "simpler" direct system with a 3-pin combo flasher and a separate plug on the headlight switch to control the corner-lamp system. The flasher is upstream of the headlight switch, so the headlight switch always receives a flashing signal unless the flasher itself has bit the dust.
92-94 combo flasher wires:
  • B ground
  • OR/L flashing output (to turn signal switch pin 1, directed by signal switch out pins 2 and 3)
frankly i much prefer the 89-91 system cuz it lets you be a lot more flexible with re-wiring the corner lamps etc. I'm going to be retrofitting that system onto the Z so i can redo the bumper/corner lights and whatnot.
Old Nov 26, 2011 | 12:11 PM
  #134
When I swapped the 92SE into the 90SE I discovered all that when I ran into a problem with the turn signals. As for the Z, I have the crazy idea of using a Maxima ECU for my radiator fan controller.
Old Nov 26, 2011 | 02:24 PM
  #135
you realize they sell fan controllers for like, $20 right?
and if you're going to use the Maxima ECU for that might as well use it to get sequential-fire as well... that's what i'm ultimately doing. Getting rid of some of the zany 80's-rific emissions nonsense and using just the maxima IACV
Old Nov 27, 2011 | 06:44 AM
  #136
so i fixed the misfire... turns out the #1 injector plug was not plugged all the way in. The 89-92 intake plate does not have enough clearance for the 93-94 plugs so they get jammed on there, apparently that one was jammed halfway off the injector.
89-92 (modified, partially milled out with a dremel/burr thing)
93-94
Old Dec 4, 2011 | 09:18 PM
  #137
Did the parallel links and trailing arms yet. Do the endlinks and rear stabilizer bushing while you're in there.
Old Dec 5, 2011 | 08:01 AM
  #138
car's already back together.. I have blehmco rear links but the heim joints are worn on them so they're clicking pretty much all the time. the bar bushings are fine tho, they're poly.. need lubing, but are still in good shape.
Wiking
40
Apr 2, 2006 09:15 PM
