Tranny Cooler questions cont...
Old Nov 9, 2000 | 12:07 PM
crsmax's Avatar
Matt...
Are the instuctions that come with the cooler sufficient (if you sort of know what you are doing...) or does it require good explanation? Has anyone done a write-up on this? Man, I'm trying to get all the information I can about these different tasks, and then as the parts start to come in, just whip out the instructions and go to work, or in the case of those more complicated jobs, get someone qualified, that (that can read the directions...)go to work for me
Old Nov 9, 2000 | 12:34 PM
Nismo87SE's Avatar
I would say for mounting the cooler itself they are. But as to were or how to mount it, they are not sufficent. My suggestion is to remove the grille to get room. Loosen the radiator mounts (upper and lower) so you can get some room. Then you have to figure out where to route the ATF lines, if you bypass the radiator itself it will be easier. But you should get a big cooler if that is the case. Also you should feel both of the tranny lines to see which one is the cooler one, because the cooler one is the return line. You should have about 2-3 qaurts of ATF too because Eric and I drained about that much when we did his.
Old Nov 10, 2000 | 11:44 AM
crsmax's Avatar
Thanks Nismo, I wish there were some pics though
Old Nov 10, 2000 | 11:54 AM
Canuck's Avatar
Go to http://grprete.jnet.net/Greg's%20Gar...n%20Cooler.htm
it has a great set of detailed instructions, and lots of pictures. I am going to install mine this afternoon.
I'll tell you how it goes.
Old Nov 10, 2000 | 05:19 PM
whitymax's Avatar
this maybe a dumb question but will lowering the temp in the trany about 70 degrees, mess with the computer or the overall engine? because it is droping in temp. i was just thinking about that while i was walking to dinner. thanks
Patrick
MaxStock
Dec 5, 2016 05:19 PM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
