Sunroof drain exit tube location?
I've been looking around threads but the only one I got was the drain tube by the power antenna. Where exactly can I find all four exit tubes?
since there is a antenna drain tube that merges with the
passenger rear roof drain tube
Yup. I know where the drain hoses by the roof are located. Using the water drip test won't work because it's pretty darn clogged. I'm not sure if the round shaped thing at the bottom of the rear wheel well is the exit for one of the tubes. But there's nothing like it by the driver's side.
They are all pretty tucked away. But the front two are in the A-pillars and end near the side kick panels beneath the dash. I know the fronts are two peices. Once peice connects to the sunroof, then there is a "joint" where the estension tube connects and channels the water down into the rocker panel (front) or bottom rear quarter (rear).
Forge277
Jun 13, 2016 09:26 PM
hayne
Oct 5, 2015 11:53 AM
