Struts and lowering springs
Old Feb 11, 2012 | 10:14 AM
nyc_ink's Avatar
questions are number to avoid confusion. 1,2,3,4
im looking into replacing my rack and pinion so i want to get the
struts and springs all done at once to get a bulk price from my mechanic.
1.gabriel, kyb, monroe or SPRINT PERFORMANCE? which are better?
2.should i replace all 4 or just the front? the rears seem fine.
3.also im looking at lowering springs from k-sport and drop zone's.
which of these are better?
dont say eibachs cause i cant afford those
4.will i lose comfort if i get the lowering springs?
if the answer is yes, i can still use my current springs or replace those?
i would like to see pics of 3rd gens with lowering springs installed to see how it looks.
i have 17'' rims btw.
Old Feb 11, 2012 | 11:01 AM
James92SE's Avatar
2 VE's are better than one!
1. Gabriel and Monroes are the same struts with different branding. They are somewhat low-end but can be had for cheap. I just put them on my black VE and my impressions are they are somewhat stiff. I would definitely not use Gabriel/Monroe if you're lowering the car unless you want to replace the struts again in a year. KYB is about the best you can get nowadays, but still not ideal for lowering. But you dont have much choice. What do you mean by "Sprint Performance"...?
2. Of course you should replace all 4, you don't HAVE to, but why not?
3. I would bet money K Sport and DropZone are the same springs. Add Aerospeed in that mix too if they're even still around. Chrome had K Sports with no issues but I haven't heard of any 3rd gen with DropZones. Again, I would bet they're the same anyway, so go with whatever you can get a better deal on.
4. Uhh, yes, quite noticeably - but surely you knew that right? Not sure what you're asking with the second part of your question there.
Come on man do some searching. There's even a huge picture thread. Most of the lowered/heavy modded guys are long gone anyway so you're unlikely to get anything "new" in this thread picture wise. You can see mine in my sig, lowered on Intrax/Tokico for 11 years now.
Old Feb 11, 2012 | 11:45 AM
nyc_ink's Avatar
[QUOTE=James92SE;8358880]1. Gabriel and Monroes are the same struts with different branding. They are somewhat low-end but can be had for cheap. I just put them on my black VE and my impressions are they are somewhat stiff. I would definitely not use Gabriel/Monroe if you're lowering the car unless you want to replace the struts again in a year. KYB is about the best you can get nowadays, but still not ideal for lowering. But you dont have much choice. What do you mean by "Sprint Performance"...?
so the kyb's sounds like the winner even if dont lower it
my back ones seem fine and itll be cheaper to replace the fronts for now but i get your point on dong all.
3. I would bet money K Sport and DropZone are the same springs. Add Aerospeed in that mix too if they're even still around. Chrome had K Sports with no issues but I haven't heard of any 3rd gen with DropZones. Again, I would bet they're the same anyway, so go with whatever you can get a better deal on. drop zones are $105
yea and no, i heard of diff stories. wanted to hear more input cause i have never had a car lowered. i dont want a bouncy stiff car so ill just keep my current ones and paint them.
dude i searched and found only one thread asking about my topic but it wasnt helpful. thats why its a forum so ppl can ask questions hoping to get an answer. thanks for your info btw
Old Feb 11, 2012 | 12:16 PM
James92SE's Avatar
I got ALL FOUR of my Monroes for about $100 total on wholesaler close-out on RockAuto. It was too good of a deal for me to pass up that I bought ANOTHER set that I'm keeping in the attic for a rainy day The ride isn't "bad" - just stiffer. KYBs would be closest to stock, though.
"Bouncy and stiff" is definitely how I would describe the average lowered 3rd gen. The reason is because when you put on lowering springs, you further reduce the travel of the strut, and 3rd gens have short struts already. But having said that, it's something you get used to. Like I've said, I've been on Intrax/Tokico for 11 years now, and you definitely learn to drive it a certain way to avoid rough patches/potholes/ridges/etc. It's a trade-off between comfort and looks. And this is why I have two 3rd gens, one stock restored and one heavily modded
What do you mean you're going to keep your current ones and paint them?
I guarantee you there's hundreds of strut/spring threads on here over the years. Anyway, here's mine on Intrax/Tokico (1.75" drop - this setup is now on my blue VE):
Old Feb 11, 2012 | 12:50 PM
CMax03's Avatar
I would try the Monroe/Gabriel strut if the dropped springs are more the 1.5" in drop...and stiffer strut controls a drop spring better...If your ride is bouncey that means your strings are overpowering the struts....I'm running Suspension Techniques who's been around since the late 60's and since my swaybars are ST's the springs designed to run with them are ST's and their spring rates are slightly higher than stock gaving me a very smooth and stable ride....even bad roads aren't bad....as for changing just 2 struts that's a waste of money and time, do all 4!!! I like my KYB's and have used them on many different setups/cars and I've never been dissatisfied!
Old Feb 11, 2012 | 12:52 PM
nyc_ink's Avatar
@ james, sweet ride and i meant by keeping them and painting them is keeping the stock springs and cleaning them and spray painting them. if your willing to sell your attic stash ill be interested in buying them.
Old Feb 11, 2012 | 12:56 PM
nyc_ink's Avatar
@ cmax, the lower springs claim to be 2.2 drop front and rear. so the gabriels would do fine with those?
the drop looks good btw.
@james whats your input on cmax's reply bout using gabriels on the lowering springs
Old Feb 11, 2012 | 01:19 PM
RotaryHead's Avatar
i run the kybs front and rear like em but a little to soft cause im runnin coilovers all the other cars i had with the kyb shock felt good. yea never ran lowering springs in the max and sence we dont have that much travel when we lower our cars anyway i went with coilovers and im customizing the shocks for more travel. i would change all the shock together as the handleing will change if you only change one side
Old Feb 11, 2012 | 01:21 PM
James92SE's Avatar
There's no way the springs are 2.2" drop. I know they list them as that but there is absolutely no way, I guarantee it. Chrome says the same thing and is convinced they're actually that low - but if you look at his pictures his car isn't even as low as mine. But I think he wants to believe it so he convinced himself it actually was 2.2"
Based on Chromes pictures I'd say the K Sports are actually about 1.5-1.6" ish drop.
As far as the Monroe/Gabriel struts - I by no means meant to imply that they're "stiff" due to any high-performance standpoint. If anything, they're "stiff" because they're cheapish. Strangely, the ride feels stiff even though the struts themselves could be easily compressed by hand right out of the box (which is generally the sign of a worn/bad strut). But yeah, I won't sell my other stash of them because I'm saving them in case I ever want to put the blue VE back to stock. Check RockAuto though there may be some more struts on close-out
Old Feb 11, 2012 | 01:38 PM
nyc_ink's Avatar
i can get all 4 kyb's for $220 i might just get these
Old Feb 11, 2012 | 01:40 PM
nyc_ink's Avatar
lol thats eff'd up they false advertise them.
but thats what they all say. the ksport ones are orange $132 and the dropzones are red $105.
Old Feb 11, 2012 | 03:19 PM
chrome91's Avatar
i figured it out last year, they were 2.2" in the front and 2.0" in the rear. theres Ksport springs and then theres Ksport GT which are lower, i had GT. pics i had were right after they were put in, when they settled the rear wheels went into the fender a bit and the fronts sunk into the front fender
it was so low that when the guy bought it from me, he didnt think he could get it on his flatbed. he had to gun it up and the fart can was scrapping. he did a huge one tire fire up the ramp with a knocking engine
i had KYB GR2 struts that were pretty old and they held up until the car got scrapped, dunno about ride quality really because i dont pay attention to it.
this pic is the day right after the springs were in so theyre not settled
Old Feb 11, 2012 | 03:54 PM
nyc_ink's Avatar
@ chrome, thats the same color max i have but i have the brougham edition . im going to just change the front ones cause there the only ones i feel, like i said before the back dont bounce at all so there still good. i wont lower it after all cause its gonna cost too much. maybe next tax return lol. mine looks lowered in the back because of the tire size i have on 17" rims, ill need to match the front tires like the back to make it look lowered.
Old Feb 11, 2012 | 04:47 PM
chrome91's Avatar
yeah i was gonna run my 17" Volks on it but the car blew up before i could get the spacers i needed for the rear so i sold them. my KYB's and Ksports are being rocked somewhere because a buddy saw my 3rd gen at the junkyard and someone took all 4 struts
never going that low again though, especially on the 3rd gen the oil pan was too close to the ground for comfort, and in winter the underside would constantly drag
Old Feb 11, 2012 | 10:04 PM
CMax03's Avatar
I have some stock springs.....in my small inventory...but why not grab some out the bone yard?
Old Feb 11, 2012 | 10:12 PM
nyc_ink's Avatar
damn so i guess dropping isn't a good idea after all. last thing i need is bottoming out and eff'n up my pan and muffler. there's too many drive way ramps here
Old Feb 11, 2012 | 10:17 PM
nyc_ink's Avatar
isn't that dangerous? won't the springs pop out and break my face lol. plus why should i get stocks if i already have some on lol
Old Feb 11, 2012 | 10:44 PM
chrome91's Avatar
to get the springs off you need a spring compressor, and yes if you do that wrong you can **** yourself up pretty bad when the spring flies off
his trailer was a 45 degree angle so you wont scrape your muffler on normal driving really, i scraped my underside on speedbumps if i didnt go on a crazy angle and slowly though. oil pan never took any hits but i was paranoid on it.
roads here are terrible though so it could be different for you
Old Feb 11, 2012 | 11:00 PM
nyc_ink's Avatar
roads here suck lol
Old Feb 12, 2012 | 12:35 AM
maximo018's Avatar
If you leave the upper strut mount bolted up and loosen the strut bolt itself slowly the strut will slowly drop relieving the pressure on the spring. Therefor if it were to shoot free it would be down to the ground plus the strut would be in the way. I speak from experience. I've done this on all 4 of mine when changing out my suspension.
Old Feb 12, 2012 | 12:38 AM
maximo018's Avatar
Give me a few days and I'll post a pic of mine. Tokico blues, Sprint springs (real 2" drop), on 350Z 17x8 all around.
Old Feb 12, 2012 | 03:58 AM
maximagician's Avatar
I scraped my underside on speedbumps if i didnt go on a crazy angle and slowly though. oil pan never took any hits but i was paranoid on it.
my front mudflaps scrape the most as they hang down the lowest
followed by the sway bar mount brackets
third would be the front tow hooks
4th would be the muffler tips
none of the above being any sort of big whoop....praise the lowered
this is on tokicos that were old when they came on my 1st maxima
and sprint springs i came across a litle later,all this being like 10+years ago
Old Feb 12, 2012 | 07:46 AM
CMax03's Avatar
Extreme dropping isn't a good idea...keeping it .5"-1.75" is a good realistic drop that's functional! I'm dropped 1.5" and I never scrape nor do I have to enter or exit driveways slanted! My ST's are functional!
I would recommend a spring compressor being used @ the boneyard, or a chain...pulling coil springs off are dangerous and can knock your head clean off if it were to pop off....just remove the strut and take the springs...These OEM spring are long as hell by the way!
You better be careful Maximo The spring still is full of energy after you relieve 1" of pressure off it there is another 3"-4" of coil extension to be releived...You're taking a chance doing that if one of these struts ever get at the wrong angle you can get severely injured or killed....be careful! The What if factor can happen!
Old Feb 12, 2012 | 10:27 AM
maximo018's Avatar
Thats why I still treat it with respect and go very slow from inside the engine bay or from inside the car with the door closed (like a chicken ).
Old Feb 12, 2012 | 01:04 PM
chrome91's Avatar
cant find it now, but theres a thread on another forum where a guy and his buddy were changing springs and he screwed up and the spring cut his whole leg open really deep
Old Feb 17, 2012 | 02:45 PM
nyc_ink's Avatar
can bad strut mounts cause a rough ride?
cause i can see the bushing from the mount when i pop the hood and they are cracked.
i was wondering if this is what is causing the rough ride thru speed bumps. i pushed the car down in the front and it doesnt bounce at all and the autozone guy said if it bounced up and down more than 3 times the struts are bad.
im no expert and i need a quick reply because im about to order new struts and dont know if should.
Old Feb 17, 2012 | 02:48 PM
nyc_ink's Avatar
also i forgot to mention that when i step on the brakes a weird sound happens like metal rubbing on something almost like a crunch/rubbing sound. im eff'n lost right now. my control arms* and end links and tie rods are like a year old.
Old Feb 17, 2012 | 03:20 PM
chrome91's Avatar
how much meat is left on your pads? check that, and see if anything is rubbing
Old Feb 17, 2012 | 03:29 PM
nyc_ink's Avatar
its not the pads bro i changed them two weeks ago. i got ceramics. maybe warped rotors?
Old Feb 17, 2012 | 05:41 PM
chrome91's Avatar
if your rotors are warped, your brake pedal will pulse like a motherfuka. only way rotors will warp really is if you heat them up really hot and they hit cold water
if you think its the rotor, remove the wheel and get a dial indicator, if the runout measurement is more than .003" your rotors need to be machined. that wont cause weird sounds usually though
did you use brake lube on all metal to metal contact areas? slide pins arent seized?
Old Feb 17, 2012 | 06:08 PM
nyc_ink's Avatar
oh ok so its not the rotors then. yea i lubed it all over the shims too. its only when i brake and it does it too when i release the brakes. it comes from the driver side. it sounds like that pin from the door when its messed up it makes a metal rubbing noise. its in the strut area cause i hear it perfectly. its driving me ****** crazy lol
Old Feb 18, 2012 | 03:02 AM
CMax03's Avatar
Hell jack up or lift your car it could be the LCA bushings, hell you can inspect it can't you? Why ask b4 you even look?
Old Feb 18, 2012 | 06:50 AM
nyc_ink's Avatar
why would i ask if i didnt look first, of course i checked, all front end bushings are still good, nothing has play in it, everything looks fine hence thats why i asked just incase someone ever had the same noise problem
Old Feb 18, 2012 | 08:19 AM
James92SE's Avatar
wat.
Anyway, did you use any lube on the back of the pad shims themselves? The shim in between the pad and the caliper that is. Did you "bed" the pads in properly? This is extra important on ceramic pads.
Did you use new rotors as well and/or get your rotors re-surfaced?
Old Feb 18, 2012 | 09:04 AM
nyc_ink's Avatar
wat.
lol theres a pin thats holds that latch in the middle of the door in between the hinges ill take a pic today.
and yes i did all that besides getting new rotors. it was doing this with my old brakes as well so its not my pads.
Old Feb 18, 2012 | 11:29 AM
chrome91's Avatar
you have to lube all metal to metal contact with brakes. if your old pads did it, im thinking your suspension is making the noise
Old Feb 19, 2012 | 03:18 PM
nyc_ink's Avatar
yea im thinking its the struts or the mounts cause the springs cant make that noise can it?
Old Feb 20, 2012 | 06:32 PM
shiloh51933's Avatar
When I replaced the LCA's, tie rods/ends, ball joints, sway links and sway bar bracket bushings I had a crunching sound on driver side when braking hard. It wasn't brake issue regardless that brake system as a whole was new. I figured either strut mounts or maybe a motor mount. My front motor mount was only six months old but it was a Duralast from AZ, so I was suspicious. It turns out that the AZ DL motor mount failed less than 6 months later on a rarely driven Maxima. My strut mounts were worn but mainly fail during quick bumps in the road. Just my experience with my Maxima, your issue could be totally different than mine.
Old Feb 21, 2012 | 07:53 PM
nyc_ink's Avatar
thats exactly what im talking about bro it does it when braking moderate and braking hard. its a crunching sound. its annoying. so the motor mounts might be the culprit ?
Old Feb 22, 2012 | 11:17 AM
La Zona Imagery's Avatar
ok I have decided to change the timing belt myself...ordering the parts today. Wish me luck
