help me out here guys
Old Mar 6, 2012 | 12:05 PM
drkwlf's Avatar
im running a 93 maxima with a ve30de,has a T04E turbo @ 12psi everything on it ive had to build myself (see pics) but as we all know there is some stuff we cant build i need help finding parts can you help me out
Old Mar 6, 2012 | 12:38 PM
DanNY's Avatar
Ad·min·is·tra·tor
yeah...about those pics....
Old Mar 6, 2012 | 12:42 PM
drkwlf's Avatar
what about em?
Old Mar 6, 2012 | 12:44 PM
DanNY's Avatar
Ad·min·is·tra·tor
i don't see any pics...
or is it just me?
Old Mar 6, 2012 | 12:46 PM
drkwlf's Avatar
lol i put them on my profile? should be like 6-7 of them
Old Mar 6, 2012 | 12:48 PM
Maxpwer's Avatar
No turbo, no care!
You don't mention what parts you need, but I'm sure a few guys on here can help you find just about anything turbo related you could need.
Do you actually have the turbo installed and running on the car yet? What did you do for exhaust manifolds? You say you have a TO4E, based on the pictures its clearly a T3/T4 hybrid, what size compressor and turbine wheels are you using? What are you using for tuning and what size injectors? What other modification have you done to the car?
Old Mar 6, 2012 | 12:52 PM
DanNY's Avatar
Ad·min·is·tra·tor
is the system actually IN the car or is it on a bench?
storing turbo parts in the trunk technically doesn't mean you have a turbo in your car.
Old Mar 6, 2012 | 12:53 PM
drkwlf's Avatar
its on the car and running the motor is stock so far i had f1 dyno(shop down the road "reprogram" the ecu when they dynoed it) but im looking for a bigger throttle body,injectors i built the exhaust its 2 1/2 duel from the cat back its pretty all the "little" things i cant build i need
Old Mar 6, 2012 | 12:54 PM
drkwlf's Avatar
no its all running i drive it everyday year around
Old Mar 6, 2012 | 12:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
do you have pics of the turbo under the hood?
what is the shop using the reprogram the ECU? i'm on the fence on getting something else for engine management.
Old Mar 6, 2012 | 01:04 PM
drkwlf's Avatar
to be honest i have no clue what they used to re-tune it all i know about the ecu end of it is after they tuned the car it made a huge diff in how it ran,they did tell me i should look for a 300zx turbo ecu and they could do something to that (getting rid 2 maf sensors down to 1) and id be a lot better off. when it comes to the computer end of building the car i let them deal with it, i been building cars for 30 years and i learned one thing "if ya dont know take it to someone who knows"
Old Mar 6, 2012 | 01:06 PM
drkwlf's Avatar
and i do have more pics ill be posting them as i dig em up and stuff
Old Mar 6, 2012 | 01:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
enh?
walk outside...open hood...take pics.
comes in...upload.
done.
don't need to have a model on the hood or anything
Old Mar 6, 2012 | 01:17 PM
drkwlf's Avatar
lmfao im gona take it ur not in maine its still covered in snow i been using my envoy cuz of the ice and crap we got id never get back up my driveway ill throw up some pics asap tho lol who knows maybe "model" and all nothing hotter then chicks and turbos lol
check the nopi website there might still be pics of it up there from when they came to NH
Old Mar 6, 2012 | 01:23 PM
drkwlf's Avatar
OH and i need to find a 2800-3000rpm torque converter will one for a 300zx fit my trany ive been told they will swap
Old Mar 6, 2012 | 01:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
pro torque can make you one. give them a call.
Old Mar 6, 2012 | 01:34 PM
drkwlf's Avatar
very cool ill have to check em out
Old Mar 6, 2012 | 03:46 PM
Maxpwer's Avatar
No turbo, no care!
I'm gonna have to call
There is 7 pictures, 3 with an intercooler on the front of the car, and none showing most of the parts needed or installed on the car. If you are so mechanically inclined and built all the stuff needed why don't you have pictures or info on all that? You avoided my question about what you did for an exhaust manifold for the turbo.
Also there are very few shops in the country that can modify a 3rd gen ECU to accept changes. You are telling me you just happend to stumble into one without knowing it? For some reason they could chip and modify your ECU, dyno tune it for a turbo system, and they couldn't even tell you where to get higher flowing injectors for your car? Not to mention you are running stock injectors with a turbo, how much power could you really be making? 250hp crank? Even that would really be pushing the stock injectors, and the stock automatic transmission.
Somethings are not adding up...
Old Mar 6, 2012 | 05:35 PM
drkwlf's Avatar
lol first off im a photographer and if you had any idea how many pics i have to go threw to find anything you understand the pics that i put up are a few of the ones off my FB
second,exhaust manifold ya built it pretty much reversed the head pipe built the bracket to use 3 of the bell housing bolts just under the dis. in front of the trany like i said before i have built pretty much everything for it myself including brackets
third, i havent been to there shop or called them yet to even asked them figured i could get some advise from a few people on here first before **** away a bunch of money having them build MY car for me id rather do it myself
ok as of right now,
yup the turbo is on the car and it is running very good,now ill list **** for you
of the things ive bought NOT built
turbo,9-12psi external waste gate,braided feed line,oil line inlet and outlet flanges,inter cooler & duck work clamps that crap,oil pan flange for the return line,a/r & vac/boost gauges,voltage gauge
and thats about it for what ive paid cash for the rest of the stuff i have built like the head pipe because the turbo isnt on the exhaust manifold its mounted to a bracket bolted to the bell housing and the head pipe bolts to that the brackets to mount everything else inter cooler duck work and all that stuff ya not hard to figure out i built that stuff as well, anything else you would like to know?
as far as what F1 dyno did to the ecu and how they did it all they said was they pop tuned the computer remember this wasnt ever a turbo car im not running half the sensors most turbo cars have so everything is adjusted by hand including fuel pressure,boost,the waste gate.i dont get out my lap top when i want to fix something i get out my tools. and to date ive got less then $2000 invested in my car
Old Mar 6, 2012 | 05:44 PM
drkwlf's Avatar
and the whole point to me coming on here was to get help with **** not be "called out" i mean if you dont want to help me out with some advise on what i should get what size who to ask thas fine. i know there are a lot of people on here that have built turbo maximas the same way i am doing pretty much the same things i have
Old Mar 6, 2012 | 05:59 PM
drkwlf's Avatar
as for whats on my page and whats not? um not a whole lot on yours there either guy
Old Mar 6, 2012 | 06:03 PM
drkwlf's Avatar
im not here for bragging rights pissing contests about who spent the most money just here for advise.or paid a ton a cash for the new "cool" part im just asking for advise nothing more nothing less
Old Mar 6, 2012 | 06:04 PM
DanNY's Avatar
Ad·min·is·tra·tor
you're not the first guy to show us pics of turbos that's not installed and can't come up a reasonable response when the questions are asked. so we just shoot up the BS meter...we don't care...just that for the ppl to actually DID the work spent a lot of time and etc on it.
trust me...every turbo 3rd gen here are pretty much custom built...yes braided lines and etc.. there's no "kit" for these cars.
Old Mar 6, 2012 | 06:08 PM
drkwlf's Avatar
trust me i know,try being in maine and doing it there is nothing here to start with so anything i have to buy is a huge pain so i kinda like to ask around before i start droping a bunch a cash to find out i didnt need something
as i find the pics and stuff i will be putting them up its not a matter of not having then its a matter of having way to many pics on my computer
there is a folder of pics on FB of my car with the first body kit on then some of when i put this kit on it after i got hit by a moron trying to pass in the break down lane that kinda crap
Old Mar 6, 2012 | 06:20 PM
drkwlf's Avatar
*neoprene swing arm bushings forgot those lol
Old Mar 7, 2012 | 07:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
no worries...post when you have them. spring is coming.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
