rear disc brake conversion help please
Old Mar 18, 2012 | 06:04 PM
dadswieser's Avatar
So I have searched around the .org site and the web for information on converting my rear GXE brake system for the SE disc brakes, so far havent found much more than a few broken links. I have a worthy 91 GXE and a donor 89 SE but Im not sure of its diff level or cost. If I were to try this procedure is there still enough information out there to guide me along? Any advice?
Old Mar 18, 2012 | 06:13 PM
Matt93SE's Avatar
STFU n00b!
http://blehmco.com/faq/rear_disc_conversion.html
http://blehmco.com/faq/rear_disc_conversion/
should tell you everything you need...
Old Mar 18, 2012 | 10:27 PM
Laevateinn's Avatar
Since fluid volume and pressure in a wheel cylinder is different than a caliper, you might want to replace the proportioning valve too. not replacing it might cause a big delay/grab in your rear wheels.
Old Mar 19, 2012 | 08:17 PM
Matt93SE's Avatar
STFU n00b!
Never had a problem with mine when I converted..
Old Mar 20, 2012 | 06:53 AM
dadswieser's Avatar
Well guys I decided not to do this procedure on the maxx because I simply have too much other stuff to do right now. I have two timing belt/water pump procedures to do and two LCA bushing procedures, a complete tune up/oil change/O2 sensor job on mine so I can go to emissions this month, plus the wife’s Durango needs some brake work and window regulators replaced. I also have a 94 Chevy S10 and a 91 Mazda Navajo that need a little attention before I can put them up for sale. If I were to pull the things needed off of 5-speed SE donor in the shop it won’t be a rolling chassis and will be harder to get to the JY. Besides for me it’s not so much about the mods as it is about just having a good dependable, reliable stock daily driver. I did pull the manual transmission from the donor and everything else I could think of (starter,alt,door switches, regulators, front clip, bumpers, etc etc) so I will store all that away for if/when ever needed.
But yea thanks for the feedback and the information links, not too scuured just too busy...... hahaha
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
