tilt steering loose>93 SE
Old Mar 19, 2012 | 09:15 AM
jona571's Avatar
does anybody know how to tighten up my tilt steering wheel on my 93 SE max??? keeps falling down and wheel moving all over the place
Old Mar 19, 2012 | 08:12 PM
Matt93SE's Avatar
STFU n00b!
If the tightener lever thingy is too loose to hold the wheel, I noticed on my 240SX that you can remove the plastic housing around the steering column and on the other side of the lever is an allen head bolt held in with a spring clip to keep it from turning- the adjuster lever is just a large nut with a handle on it basically.
pull the plastic housing off the column and see if you can find that.
HTH.
Old May 4, 2012 | 01:16 AM
jona571's Avatar
HTH.
you are right I fixed it thanks to you
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
