92 maxima with dohc engine problem
Old Apr 18, 2012 | 01:35 PM
focusurmaxima's Avatar
I have a 92 maxima with I believe a ve30de first off I'm not losing any money I only paid 150 bucks for it
I know the Guy I bought it from it use to drive great.
anyway 2 of the 3 (left and middle) spark plugs are crushed.
What should I do buy another running engine or try and salvage mine?
any advice is appreciated
Old Apr 18, 2012 | 01:43 PM
It had a little knock about 500 miles before it died
Old Apr 18, 2012 | 02:57 PM
KenBob's Avatar
The spark plugs are crushed? I hope you mean that they are broken in the head or something else, otherwise I would love to see pics of this!
Old Apr 18, 2012 | 03:54 PM
No literally ill take pics this evening 2 plugs are crushed like piston or valve hit them
Old Apr 18, 2012 | 05:36 PM
Laevateinn's Avatar
If the piston or valves hit the spark plugs, the timing was screwed. Did the chain break or skip?
Old Apr 18, 2012 | 06:15 PM
T_Behr904's Avatar
How can the spark plugs get crushed unless they were the incorrect spark plugs that were installed? The piston has a set travel and only goes so far up and down.
Old Apr 18, 2012 | 07:33 PM
KenBob's Avatar
The only other thing that would be possible is if the engine it self ingested something as a screw or whatever, but I can't image a small piece of foreign material truly "crushing" a plug.
Old Apr 18, 2012 | 08:07 PM
LvR's Avatar
LvR
Also possible that "knock" was the piston announcing its arrival at the head due to a big-end bearing failure I guess .....................
Could be over-revving and a piston disintegrating...........
I say remove heads and drop sump to look in detail at that particular cylinders before you decide how to proceed ............... any one of those and I would rather replace the motor.
Real strange to have 2 cylinders on different journals on the crank showing up with mechanically damaged upper components - makes me think we are not getting the whole story
Old Apr 18, 2012 | 08:16 PM
T_Behr904's Avatar
If that's the case, then there's catastrophic engine failure. Removing the engine and taking it apart will reveal what really happened.
Old Apr 18, 2012 | 08:19 PM
Timing chain appears to have skipped but there are to quarter size holes in the timing cover nothing was ingested in the engine and they are the correct plugs th car was running Driven daily till it died
Old Apr 18, 2012 | 09:57 PM
maximo018's Avatar
Unless you have the mechanical know how & feel up to it I would replace the motor at this point. Its easiest and less down time. You can rebuild original on the side while your still able to drive your car.
Old Apr 18, 2012 | 10:07 PM
LvR's Avatar
LvR
Agreed - the fact that this thread was even started is a sure indicator that its the best solution
Old Apr 18, 2012 | 10:11 PM
maximo018's Avatar
Just thinking if it were me. I wouldn't even want to be bothered by it right now.
Old Apr 19, 2012 | 12:14 AM
maximagician's Avatar
no distributor but 6 coils=ve30 dohc
has distributor and 1 main coil =vg30 sohc
How many miles on the car?is it a 5 speed or automatic? what color paint?
Old Apr 19, 2012 | 10:45 AM
It's a 92 gold maxima it has 370,000 miles on car the engine appears to be original has about 3/4 an inch of road grime all over it trans only has about 1500 miles on it ( main reason I bought it ) everything works windows,seats,sunroof,radio all of it works . And again $150
I got my money's worth
Oh and it's a 5 speed
Old Apr 19, 2012 | 01:28 PM
Augustus Maximus's Avatar
Buy my engine.
Old Apr 19, 2012 | 03:13 PM
Originally Posted by Augustus Maximus
Buy my engine.
How much for ur long block?
How many miles?
Old Apr 19, 2012 | 06:12 PM
Cliff Clavin's Avatar
Way out West
Don't toss the engine that's in it. At least be sure to keep the upper intake. 5-speed ones are kind of hard to find.
Old Apr 19, 2012 | 07:48 PM
maximo018's Avatar
Who you telln? I thought VE5 were almost unicorns back when I was looking for mine 3 years ago. Now The only place I see new ones (other than mine) are here on the org or in the jy.
Old Apr 26, 2012 | 07:31 PM
I finally found the engine 105,000 miles $350. Good deal?
Old Apr 26, 2012 | 07:45 PM
chrome91's Avatar
does it come with all accessories (alternator etc)? if it does thats pretty cheap
Old Apr 26, 2012 | 08:45 PM
Buy the engine.
Old Apr 27, 2012 | 12:35 AM
Laevateinn's Avatar
That's a very awesome deal for a non-cracked block
Old May 1, 2012 | 02:11 PM
After 4 days and nights it's in and running I thing it has a bad injector or something but I still have my old motor w/ acc
Still needs vacuum lines routed
And my 5 speed intake on it
But getting closer
Old May 1, 2012 | 06:25 PM
Way out West
ha! I think I just found the new nickname for my car -- The Unicorn!
Old May 1, 2012 | 08:25 PM
maximo018's Avatar
Mine is primered out right now, but I notice she starting to get looks. (Gotta get an alarm).
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
sc10692
Aug 9, 2015 09:37 AM
