here's a tough question - black window lining
the hard black lining that rests between the windows and the door is starting to crack and peel. I'm sure everybody has had this problem at one time or another if you've had a older car. Nothing seems to stop this from ageing over time. Where can i get a replacement for these parts and what are they called?
Re: here's a tough question - black window lining
not positive, but i heard in a recent post that courtesyparts.com (nissan parts distributor of courtesy nissan) has any part you need even if it's not on their site. go there and try emailing them, either way there's cool stuff on there anyway...good luck.
I just ordered a bottle of this
http://www.urethanesupply.com/3400.htm
Someone else mentioned this product a while back, I'll post my results after using
Re: I just ordered a bottle of this
That stuff costs $15. You can get a brand new replacement from Nissan and the cost is not much more (like $20-25).
The problem is knowing how to remove the old trim. I tried but could not figure it out.
If anyone knows how to remove the old trim........PLEASE let us know.
Originally posted by James92SE
Brand new window trim for $25??? Where?? Heck, I'd go for all new trim if that's the case. Got any more info on that?
please help..
James.. nice rims man!
To be or not to be
Originally posted by superdesi That stuff costs $15. You can get a brand new replacement from Nissan and the cost is not much more (like $20-25). The problem is knowing how to remove the old trim. I tried but could not figure it out. If anyone knows how to remove the old trim........PLEASE let us know.
at your listing price. Besides my windshield and rear glass side moldings are fading also. For $15 if this bottle doesn't satisfy my desire I'll probably go the sand paper route and set aside Sat morning and afternoon to do the job correct. Masking and spraying to the third power
I "think" in order for the window moldings to come off the door glass has to be removed.
Re: To be or not to be
If all four window moldings are fading replacment can cost over $100+
Re: Re: To be or not to be
Originally posted by perfectmax
How did the window trim turn out using that stuff in the $15 bottle.
All it does is dye it. And it's a very weak dye at that. I did like 5-6 coats, and it was just BARELY darker. It also did nothing for the actual sun damage (you know where it looks kinda crumbly). Soo, even after it, you still have that faded crumbly part mixed with the <i>slightly</i> darker semi-shiny part...
I think that stuff should mainly be used for thin thin actual soft rubber molding. Seemed to work ok on that stuff, but not really on the parts we need it done on (belt moldings - the 'technical' name).
Re: Re: Re: To be or not to be
They are called belt moldings and they cost $163.94 for all 4 of them + shipping. I got this straight from Kaleb that works at Courtesy. He posted this a while back on another forum.
Call them up I am going to replace all of mine after I paint my car.
Sorry I'm getting a bit confused.
Belt moldings are the thick moldings at the base of the side windows right?
I'd like to know how to remove these as well as the trim around the front windshield. I remember searching for this last one a while ago, but couldn't find anything. I have to repair some small rust bubbles around there and need to take the trim off first. I hope you don't need a special tool or something to pry them out....
yes the belt molding is the black under the windows. I will be playing with taking it off of my parts car (dont want to screw mine up) to see how they come off. I will probably do that this weekend if I have time.
if you want a simple & cheap fix, just scrub some armor-all in there...i just wrap my finger in my armor-all rag and go back and forth along the black trim. Doesnt make it look brand new but its an improvement...just do this everytime you wash it
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
