flushing the radiator tommorow...........
Old Jan 5, 2002 | 05:12 PM
JerseyKRS's Avatar
Where the hell is the coolant drain plug?? And the thermostat for that matter? I am probably just overlooking them. My heat doesn't blow too hot and I'm hoping this helps. I read the posts on other ways to fix it, but I'll try this first. The temp. gauge doesn't really move past the cold position and when it does it only goes up a little. Hopefully it is just the thermostat.
Old Jan 5, 2002 | 09:25 PM
PATRICK94SE's Avatar
Not 100% sure but I would assume the thermostat is where the
upper radiator hose meets the engine. Not sure though I am so used to working on my Bronco. I wish the Maxima was that easy
Old Jan 5, 2002 | 09:38 PM
flyry110's Avatar
if you ahve to ask, buy a shop manual and it'll save you ALOT of time. 15 bucks or whatever they are is well worth it!
Old Jan 6, 2002 | 04:10 PM
davis4004's Avatar
The radiator drain is on the drivers side, and it has a little hose coming of of it. The thermostat is below the top of the timing belt cover. Where the upper radiator hose goes into that metal piece there is another rubber hose that gose down and into the thermostat housing, that's where the thermostat is if you have a VG. And get a Haynes manual if you're going to be doing anything on your car.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
