no trans fill plug on mt vg
Old Jun 20, 2012 | 07:38 PM
brads91max's Avatar
i just did a new clutch kit and i cant find the fill plug for the life of me. any ideas?
Old Jun 20, 2012 | 08:31 PM
Hectic's Avatar
nicoclub.com/fsm/maxima/1994
look under MT section
Old Jun 20, 2012 | 08:58 PM
BenStoked's Avatar
Jesus was a Zombie.
speedo sensor. pull it to fikk, use the sensor as a dipstick.
Old Jun 20, 2012 | 09:24 PM
maximo018's Avatar
Its the round threaded plug with a recessed square head. Its under the front trans mount facing the front of the car. Locate the starter and it should be to the right of that (the direction of the driver side wheel). You will need a 1/2" ratchet to break it loose.
Old Jun 20, 2012 | 09:34 PM
brads91max's Avatar
i looked for that and i dont see one
Old Jun 20, 2012 | 09:45 PM
maximo018's Avatar
(man you seem to be on most of the time when I respond) lol Its under that trans mount. Its easily seen from under the car than through the engine bay. Just remove the splash guards at the bottom (if you still have any).
Old Jun 20, 2012 | 09:50 PM
brads91max's Avatar
no splash guard but i will look again in the morning
Old Jun 20, 2012 | 09:52 PM
maximo018's Avatar
Pay attention to my sig. You see where that red part of the positive batt terminal is? Straight down from there but better seen from the bottom.
Old Jun 21, 2012 | 11:24 PM
brads91max's Avatar
so no fill plug on my tranny i had to take out the speed sensor to fill it.
Old Jun 22, 2012 | 02:52 AM
maximo018's Avatar
You've got one its just camouflage well that you had to miss it. Well as long you were able to fill it. Goal obtained.
Old Jun 22, 2012 | 11:21 AM
7mJoe's Avatar
You should find it so you can check you fluid levels. You don't want to put too little in!
Old Jun 22, 2012 | 08:24 PM
maximo018's Avatar
Or too Much!
Old Jun 22, 2012 | 09:21 PM
brads91max's Avatar
i will take pics for you guys but i dont see it lol and i have to pull my tranny again cuz i got bad throw out bearing in my kit. fml
Old Jun 23, 2012 | 01:04 AM
NismoChi's Avatar
this should help
Old Jun 23, 2012 | 01:07 AM
NismoChi's Avatar
BTW, this is what mine looks like when my clutch failed.
Old Jun 23, 2012 | 11:00 AM
brads91max's Avatar
mine looked nothing like that it was just loud so i changed it and now i have to change it again.
Old Jun 23, 2012 | 11:32 AM
NismoChi's Avatar
where did you get your clutch kit at? Is it Used? If you put it in right, it shouldn't make noise. Did you DIY?
Here is my new one next to the old one.
Old Jun 24, 2012 | 02:50 PM
maximo018's Avatar
No one has yet beat the quality of OEM.
Old Jun 24, 2012 | 02:54 PM
maximo018's Avatar
Btw NismoChi where you been? Haven't heard from you in a while.
Old Jun 25, 2012 | 12:11 AM
NismoChi's Avatar
My lovely Max had been down for over two years, the clutch went out, left it parked in front of the house the whole time. Brought a used Fidanza flywheel from "Cliff Clavin" and a clutch kit, finally start messing with it two weeks ago, took out the tranny and found out the TOB broke, replace the clutch and replace some steering parts, got an alignment, have new tires to put on next week, will start driving it again really soon.
The one thing that i notice after the first time driving it in two years....the steering is really really light.....has it always been this light????
Old Jun 25, 2012 | 02:26 AM
maximo018's Avatar
Now that my 5.5 is about crippled its time to dust mine off and wake her up.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
