1991 automatic transmission interchangability/compatibility help asap!!!
Old Jun 21, 2012 | 12:27 AM
booyaka84's Avatar
I am replacing the automatic tranny in my 1991 maxima sohc vg30e and need to know which automatic trannies are intercheangable. I have sourced an auto tranny from a 94 sohc and was told it will work perfectly if the shift control unit is swapped. Please, any help is greatly appreciated.
Eric
Old Jun 21, 2012 | 12:43 AM
booyaka84's Avatar
Bump...
Old Jun 21, 2012 | 04:54 AM
Greeny's Avatar
¯\(°_o)/¯
the 94 trans will work without any modifications...the control units are the same....
Old Jun 21, 2012 | 05:04 PM
booyaka84's Avatar
Anybody else have more information on doing this conversion? I recieved an interchange report from a wrecking yard stating I would need to change the shift control unit (included with the tranny) for it to work. I am concerned this will have ill affects on my ecu/speedo/reliability/sensor compatibility etc. Has anyone done this conversion? I'm between a rock and a hard place because I really only have the budget to have one shot; labor expense wise. If it doesn't work or probs occur after it is installed I am not only having to source another tranny but also pay 500 just to pull it out and reinstall another.
Old Jun 21, 2012 | 05:06 PM
booyaka84's Avatar
All and any help is greatly wanted.
Old Jun 21, 2012 | 07:02 PM
booyaka84's Avatar
Bump
Old Jun 22, 2012 | 12:06 AM
booyaka84's Avatar
I have tried other resources and haven't got much info. Any help would be great. Thanks!
Old Jun 22, 2012 | 02:07 AM
booyaka84's Avatar
Maxima Automatic Tranny from 1989-1994, a couple of only varying differences. This one is according to Hollander Interchange# 59284B that states it fits the 1989-1993 SOHC, which is the 59284A, by switching out the control box. Can anyone help by personal experience with this conversion? Or is just certain it will work the way it is supposed to? Thanks.
Old Jun 22, 2012 | 02:44 AM
maximo018's Avatar
Your not gonna get much more than what Greeny told you>. Just swap it over. Theres no big deal except for the fact that its newer than your original.
Old Jun 22, 2012 | 11:33 AM
booyaka84's Avatar
Thank you maximo and greeny for the help. Why do I have to change the shift control unit along with the tranny? This is the part that makes me nervous.
Old Jun 22, 2012 | 12:58 PM
Greeny's Avatar
¯\(°_o)/¯
As i said before, you do not have to change out any shift control units, or anything else for that matter....the sohc auto transmissions from 89-94 are identical...
just swap it over, it's that simple....
Old Jun 22, 2012 | 08:16 PM
maximo018's Avatar
Yeah the trans ctrl unit, engine and ecu aren't gonna know the difference. As far as anything electrical or mechanical they will think that the same trans is still there.
Old Jun 22, 2012 | 11:10 PM
jbbons25's Avatar
The only time you need to worry about the shift control unit (and then other parts) is if you are trying to replace it with an auto from a DOHC Maxima.
Also, I think you are stumbled on the year because the 4th gen Maxima was released very early (2/94). So as long as you got it from a 94 model year SOHC Maxima, you will be fine.
PS: Re-posting your question on the Newbie thread is not really helping you.
Old Jun 24, 2012 | 03:14 PM
maximo018's Avatar
True. And you wouldn't be able to do that because the VE auto want bolt up to a VG. Only 5spds swap over.
Old Jun 26, 2012 | 11:34 AM
Maxpwer's Avatar
No turbo, no care!
Actually that's not true. I honestly think the only reason it hasn't been done is the misinformation. Too many people who don't know **** claiming it won't work. PLEASE don't make statements about stuff you don't know, why is that so hard?
Old Jun 26, 2012 | 02:48 PM
Greeny's Avatar
¯\(°_o)/¯
the ve auto will bolt up to the vg block, the catch 22 is the vg flexplate will not work with the ve auto starter, it wont reach the flywheel teeth...you cannot swap ve/vg flexplates, due to the ve flexplate is 8 bolt, the vg is 6 bolt...
their was some scuttlebutt some years back about the flexplate from a mecury villager/nissan quest minivans being compatible with the ve auto because the quest/villager vans have the vg engine with the ve auto trans, so it had a flexplate made to accept the ve starter...
but all this is a moot point anyway, cuz then you have to basically rewire the entire engine harness so it will run the ve auto trans....
yeah, too much work imo....
Old Jun 26, 2012 | 10:59 PM
maximo018's Avatar
Well short story gone elaborate Greeny summed it all up. This is all what was explained to me a year and a half ago. Pretty much won't work. NOT SAYING IMPOSSIBLE. But most if not all of us aren't gonna go through that much work to say we butted up a VE a/t to a VG. All that work for little accomplishment.
Oh I didn't come off on you harsh so no need to come at me as such. Have a nice day!
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
