Corner light problem
Old Jan 7, 2002 | 05:02 PM
TightBlack97's Avatar
I put some piaa 1156 extremes in the corners. On the right side it is already bright and when I put my turn signal on to go right and it is already bright so it doesnt get any brighter. The left side corner is dull when I dont have the turn signal on. I think it is a wiring problem but it will be a pain to trace it. Any suggestions?
Old Jan 7, 2002 | 05:07 PM
N34JZ's Avatar
Needs non-Maxima Friends
Re: Corner light problem
sounds like you may have the bulb in backwards unless you did the re wire mod only on one side. try to pu the bulb in there another way. you may have put a single filament in there.
Old Jan 7, 2002 | 05:51 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
don't the corners use 1157 dual filliament bulbs??
Old Jan 7, 2002 | 06:54 PM
noleafclover's Avatar
yes...sounds like you got the 1156 in the right and 1157 in the left...
Old Jan 7, 2002 | 08:07 PM
BIGDOG's Avatar
Yeah thats what it is the sides use 1157's but unless you trim the little prongs off the 1156's they shouldnt go in the holders properly. There for the bulb might be just burn out. Bc Ive gotten a bad bulb from them before and had to reorder some more.
Bigdog
tsi6001
Oct 3, 2022 10:23 PM
tnewbs
Aug 28, 2015 10:15 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
