Car still dies after starting. Now with video
Old Dec 10, 2012 | 07:13 PM
mattyd's Avatar
My 93 SE suddenly stopped starting some time ago. I've replaced some things and now have a video to show the behavior rather than describing it.
http://youtu.be/yATDeD2mWQU
The plugs are dirty but not 'fouled' per say -- I had some leak-down from the valve cover gaskets that may have gotten in to the engine.
I replaced the starter, battery, and battery terminals recently which took care of a host of other issues. I also cleaned the PCV valve, replaced spark plugs, air filter, fuel filter.
I've also tested these with no symptoms: compression test, electrical test on all ignition coils (ohm and spark), MAF, throttle position sensor. The ECU throws no codes.
Any help tracking down the cause is appreciated.
Old Dec 10, 2012 | 10:16 PM
Hectic's Avatar
Check the fuel pressure next.
Old Dec 11, 2012 | 12:15 AM
maximagician's Avatar
**edit ,i must have mis-read that as trouble getting start signal etc.
so nevermind
could it be your ignition switch?i have a spare one we could just plug in to test it by unplugging yours without removing your ignition switch . mine is from a 92 se 5mt, im in north seattle
Old Dec 11, 2012 | 06:47 PM
ghostmax's Avatar
try fuel pump relay and fuel pump. pull the back seat and check the fuel pump harness as well and look for corrosion (had a similar problem like that).
also check the ecu for any codes.
Old Dec 15, 2012 | 06:14 PM
**edit ,oops
so nevermind
let me know if you want to bring it by sometime,i stay in north seattle and i have a fsm for my old 92 which covers ve and vg and all options etc.i ve got tools and a multimeter,i dont have many ve spare parts left
but i was at pick and pull in lynnwood a while ago and they had 2 ve cars
Old Dec 16, 2012 | 05:10 AM
shiloh51933's Avatar
[QUOTE=mattyd;8682954]My 93 SE suddenly stopped starting some time ago. I've replaced some things and now have a video to show the behavior rather than describing it.
The ground on the FP sending unit is a known issue for no start condition. If the plastic insulation on the top of the sending unit cover is cracked or damaged this could cause a no start condition.
Old Dec 22, 2012 | 01:55 AM
mattyd's Avatar
[quote=shiloh51933;8686788]
Interesting -- when you say "sending unit" you mean the connectors to the pump under the rear seat or something else?
Old Dec 23, 2012 | 07:18 PM
Hectic's Avatar
I think he means the pump assembly itself. The actual sending unit doesn't do anything that would prevent the car from starting.
Old Dec 23, 2012 | 07:27 PM
ghostmax's Avatar
My fuel pump harness had actually corroded and caused a no-start condition.
Old Dec 30, 2012 | 04:41 PM
mattyd's Avatar
Fuel pressure read at nearly 0PSI so the pump is the culprit. Harness/etc. was fine.
Lakersallday24
Jun 16, 2019 01:35 AM
Maxboy23
Aug 11, 2015 11:59 AM
mikekay
Aug 10, 2015 12:52 PM
spidgeon
Aug 9, 2015 09:26 AM
13Maximasv
Aug 7, 2015 10:56 AM
