Brake upgrades
Old Jan 10, 2002 | 10:05 PM
dbithell
Brake upgrades
Has anyone done a brake swap from a 300zx, Infinity Q45, etc. I don't know what is compatible or even an upgrade. Any direction would help.
Old Jan 10, 2002 | 10:38 PM
Matt93SE's Avatar
STFU n00b!
just an FYI, All RWD nissans use the same caliper brackets. you can pull the parts off a Q45 or Skyline or 300ZX, and they'll all bolt onto the other cars with no problems. brake hose fitting may be different, but the brackets are the same.
That said, I'm running Skyline rotors and Wilwood 4 piston calipers on my car. Several other guys have used 300ZX brakes with good results- you just have to trim the diameter of the rotors by about 3mm to make the calipers fit on the OEM mounting brackets. (note the above part I said all RWD nissans have same mounting. FWD are different radius, but the bolt size and spacing is still the same)
do some searches on 300ZX brakes, you'll find quite a bit more info.
Old Jan 10, 2002 | 10:55 PM
JonnyMax's Avatar
What about the rears?
Have you upgraded them as well? I always see brake kits for fronts but never the rears... I know that the fronts work much more... but you would still think that it would be a good idea to upgrade all 4 corners.
Old Jan 10, 2002 | 10:58 PM
Matt93SE's Avatar
STFU n00b!
Actually no, you don't need to upgrade the rears..
reason being, as you go bigger on the front, you've got more stopping power up there, so more weight shifts OFF the rear wheels and onto the front wheels. Thus, you really need less braking power in the back. But obviously that's dumb, as this IS a 4dr sedan. we DO haul groceries and other stuff in the trunk. no brakes in the back in that case wouldn't be good.
Old Jan 11, 2002 | 02:52 PM
JonnyMax's Avatar
I see...
Thats interesting... Ill keep that in mind as I contemplate a nice new Big A$$ brake kit!!! thanks Matt.
Old Jan 13, 2002 | 05:31 PM
dbithell
Brake Upgrades
Thanks for the info, we'll see how it goes. Have you had any problems fitting the calipers on your wheels? I only have 16's. I know stock 300zx's came with 16's also. What are you running? Thanks again, Dan
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
