bmw e36 lights question
Old Feb 3, 2013 | 04:19 PM
mythic540's Avatar
I know this is redundant by now, but I have found a few different styles on ebay, I just want to get your guys opinions on what would fit or be easily modified to fit or at least where to get some good halo projectors around the same price....
http://www.ebay.com/itm/190733820630...84.m1423.l2649
http://www.ebay.com/itm/221164177661...84.m1423.l2649
let me know what you guys think, I'm ready to buy once I am confident getting the ones that will be possible to fit without much hassle
Old Feb 3, 2013 | 05:10 PM
James92SE's Avatar
2 VE's are better than one!
You can make either style fit. The normal OEM ones are the typical/most common install.
The projectors will require you to cut into your radiator support. So it's really up to you on whether or not you're comfortable cutting up the radiator support.
Old Feb 3, 2013 | 06:00 PM
mythic540's Avatar
so i those projectors are a bit bigger than the stock OEM ones?
Old Feb 3, 2013 | 06:17 PM
James92SE's Avatar
Yes they're deeper, which is why it forces you to cut the radiator support
Old Feb 3, 2013 | 06:33 PM
mythic540's Avatar
ok i see what youre saying, I've been reading so much about these conversions and a lot of guys are claiming the stock OEM lights arent worth putting in because theyre not as bright. I dont want to drop 100 bucks on the stock ones if I can spend the extra to get the better lights and its not that much more work to put them in, you know what i mean?
Old Feb 3, 2013 | 07:52 PM
James92SE's Avatar
I have the OEM e36 lights with HIDs, but stock they're a heckuva lot brighter than OEM Maxima lights.
Really, it's essentially the same amount of fabrication. Cutting your radiator support isn't "fabrication" per se, so I wouldn't take into account that "work" in your reasoning. Really it takes 2 minutes to cut your radiator support. Rather than the amount of work, I think you should focus on whether or not you want to make irreversible cuts into your radiator support.
Old Feb 3, 2013 | 11:05 PM
mythic540's Avatar
so its about whether or not I feel its worth hacking away at other components on my car? I really dont have a problem with that, what I dont want is to buy something that I just wont be able to make look good on my car, like for example if the lights I buy are too large to fit in the housing that theres no way to force them in there and I am stuck with paperweights at the end.
Old Feb 4, 2013 | 03:56 AM
James92SE's Avatar
The projectors ARE too big (deep), which is why you have to cut your radiator support. So if you're okay with that, then by all means go for the projectors. Whether or not either setup looks good comes down to your skill level. If you can make the OEM ones look good, there's no reason you couldn't make the projectors look good either, and vice versa. Not like you'd have the skills to make one look good but not the other as, like I said, the overall amount of "work" and skill is about equal other than one necessitating you cut the radiator support.
Old Feb 4, 2013 | 06:23 AM
DanNY's Avatar
Ad·min·is·tra·tor
take some measurements. this is the ONLY way you can determine if the lights will fit to your comfort level.
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
spidgeon
Aug 18, 2015 05:46 AM
Samuel1021
Wheels/Tires
Aug 16, 2015 03:01 PM
doobadoo
Aug 15, 2015 06:43 PM
