SE max have a timing belt?
Old Nov 11, 2000 | 07:27 AM
MAXMATT
I was just wondering if a 93 Se has a timing belt or a chain. How much does it cost to get a timing belt changed if there is one on the car?
Old Nov 11, 2000 | 07:38 AM
primeevil711's Avatar
it has a timing chain
Old Nov 11, 2000 | 08:06 AM
Tick Tock's Avatar
Yes, chain. For other curious GXE owners, belt change is typically about $400. $25 for belt, rest is labor.
If you do it, I'd change the water pump, top/bottom radiator hoses & clamps, the drive belts too. Also, check the frost plug for leaks - or just change it. Often a trouble spot and cheap to change when in there doing the timing belt. Otherwise, it's basically the same labor charge for the frost plug as doing the timing belt. Consider it a near freebie, maintenance item when doing the belt.
Old Nov 11, 2000 | 10:26 AM
Jeff92se's Avatar
I'm needing a caw
Hey looks like we have another DIY mechanic around here. Welcome dude!
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
