Radio HELP
Radio HELP
Ok, so I hooked up a newer radio to my maxima and it was working fine like it was suppose to. However, today I finally brought the antenna adapter for the radio and decided to hook it up immediately. I hooked it up and again, the radio worked fine. However, I was still hearing the alternator whine so I tied a yellow wire noise suppressor to the 12v constant wire. As I was doing that, I accidentally allowed the yellow wire to touch some metal for about 2 seconds and it smoked a little. I guess I grounded the 12v constant and so now my radio will not turn on. I thought I could solve the problem by finding a fuse, but all the ones I checked were good. I do not know what else to do. Any suggestions?
10a fuse, fourth from the bottom on the left side if you chose the constant in the audio harness. Should have spared the deck fuse if you had it connected already.
How much are you selling it for?
Edit: Thread moved, joke not funny anymore.
mikeg75
Nov 30, 2015 05:12 PM
