Question About Lowering My 92
Old Jan 13, 2002 | 02:26 PM
SOROROCKSURSOCK's Avatar
I GOT A 92 MAXIMA WIT THE 97 SE 5 SPOKE WHEELS ON IT IM WONDERING WHICH SPRINGS I SHOULD GO FOR WHEN I LOWER IT I HAD EIBACHS ON MY 97 BUT I DONT KNOW WHAT IS GOOD FOR A 92 I WANT IT TO BE PRETTY LOW CLOSE TO SLAMMED WHICH ONES IS GOOD AND IF ANYONE HAS ANY PICS OF THEIR CAR LOWERED ID LIKE TO SEE THANKS
Old Jan 13, 2002 | 02:30 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Question About Lowering My 92
first off turn off the caps lock.... anyways heres some of my car and the Sprint springs...Sprint is 1.8" drop and there is also Intrax(1.75") which will give you the slammed look too! here some pics of mine-->
http://www.fortunecity.com/silversto.../1058/id40.htm
Old Jan 13, 2002 | 04:29 PM
flyry110's Avatar
you need to give me those high 16" wheels, and i'll give you my 15's with 50 series tires. . . then you'll be dropped at least 1.5"
Old Jan 13, 2002 | 04:38 PM
Bman's Avatar
Check out Ngthing's page for a comparison of spring drops. Not perfect comparisons, but it's something. http://www.annulardesign.com/maxima/
Old Jan 13, 2002 | 05:03 PM
DA-MAX's Avatar
damn 50 series 15's.....
Old Jan 13, 2002 | 05:42 PM
Lordrandall's Avatar
Eibach's handle the best, get those.
Old Jan 13, 2002 | 05:54 PM
DA-MAX's Avatar
handling is waaaaaay overated...lower is better!!!!!
Old Jan 13, 2002 | 07:28 PM
D-sta's Avatar
Thanks for the radio. The best set in which i'm looking into buying is the eibach springs. The other thing is that you should change the shocks since when they put in the springs they have to take the shocks out. Also the benefit to this is that the shock gets use to the new ride due to the springs and if you were to put the new springs on the same shocks it will put more strain on the shocks and kill their life and eventually you will need shocks, so you'll end up paying double for labor. The best place I can recommend, is custommaxim.com, he gives you a 5% discount for being an org. member. If you want real stiff handling you need the springs $220.00, shocks $300.00 and suspension techniques sway bars w/ polyurethane bushings, i believe these go for $180 or so. Hope this helps.
Peace,
D-sta
Old Jan 13, 2002 | 10:40 PM
Mine are lower than Eibachs, more comfy too..... I guess.
Old Jan 14, 2002 | 12:06 PM
WELL I LIVE IN NYC AND ALOTA PEOPLE SAY I SHOULD GO WITH EIBACHS BECAUSE IF I DO INTRAX OR SPRINT IT WILL BE WAY TO LOW AND I WILL LOOSE MY OIL PAN BUT DOES ANYONE HAVE A 3RD GENERATION MAXIMA IN NYC WIT ANY PICS OR ANY INFO HELPIN ME
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
