The "whip" : '91 GXE
Old Jul 8, 2013 | 06:13 PM
  #121
CarlW's Avatar
So he is telling you it needs $1200 worth of work simply because it's "sluggish until it gets up there"? That's a pretty vague symptom to claim it needs that much in work.
Was the car experiencing issues that caused you to get this looked at or were you simply due for T belt and water pump?
It overheated really bad, so we took it to tuffy and said the water pump and timing belt need to be replaced. Then we took it to the backyard mechanic to do the work.
Old Jul 8, 2013 | 07:21 PM
  #122
DanNY's Avatar
Ad·min·is·tra·tor
i'm going to say that you'll be getting a different car carl.
Old Jul 8, 2013 | 07:37 PM
  #123
James92SE's Avatar
2 VE's are better than one!
"Overheated really bad" on an engine with aluminum heads usually means it's FUBAR'd
If it were me I'd swap in a used VG before dropping $1,200 just to fix a valve or two. You could probably completely rebuild an engine for that
Old Jul 8, 2013 | 08:07 PM
  #124
chrome91's Avatar
i dont know, rebuilds are alot these days. the HG blew on my Crown and i dont have time to fix it myself so i took it to a garage, estimate for a complete rebuild if the head was decked was $6000-$7000, i caught it early enough that the gasket could just be replaced and it was $3300 for the HG, timing belt, water pump, valve seals, and all that random crap
but yeah overheating+aluminum heads is bad, VG30E are cheap enough that i would look at a engine swap
Old Jul 9, 2013 | 01:19 AM
  #125
maxima278's Avatar
I say find out what's up with that black one you found first. If you had I fix one, I'd go for it rather than your GXE.
Old Jul 10, 2013 | 11:57 AM
  #126
CarlW's Avatar
I drove past there just yesterday and it was gone , im still hoping an employee owns it...
I'll see how my parents react to that, they're already complaining about putting $185 in it already.
My parents praise the current motor because it's got only 60k, but i'd like to do a swap...
Old Jul 10, 2013 | 10:12 PM
  #127
CarlW's Avatar
Guys quick question. Does my lowness matter if im on
- Intrax / stock struts
- Intrax / KYB
Intrax / Tokico
Which would be the overall lowest?
Old Jul 11, 2013 | 06:36 AM
  #128
DanNY's Avatar
Ad·min·is·tra·tor
- Intrax / KYB
Intrax / Tokico
your springs sets ride height...not the struts.
the struts just dampens the bump so your suspension is not a pogo stick.
with all your set up that you listed...they will ALL ride the same height (intrax springs)
Old Jul 11, 2013 | 07:44 AM
  #129
CarlW's Avatar
Old Jul 11, 2013 | 07:45 AM
  #130
CarlW's Avatar
thank you for the help!
Old Jul 11, 2013 | 05:40 PM
  #131
CarlW's Avatar
Guys quick question! I'm about to buy a guys 5.5 gen wheels + tires and I want to know if they'll fit right out if the box with no extra work. Will they just screw on?
Also, is there anyway to remove rust from brakes? I dont have too much, but I'd like to get rid of the little bit I have. Thanks!
Old Jul 11, 2013 | 05:55 PM
  #132
DanNY's Avatar
Ad·min·is·tra·tor
ok this thread is NOT your personal Q&A man. do a search on the wheels and see.
what part of the brakes?! rotor? caliper? splash shield? pads?
Old Jul 11, 2013 | 06:01 PM
  #133
CarlW's Avatar
Sorry.Won't happen again.
Old Jul 11, 2013 | 09:06 PM
  #134
James92SE's Avatar
Wheels will bolt right on
Old Jul 11, 2013 | 09:41 PM
  #135
CarlW's Avatar
Phew, that's good to know! Thanks James, appreciate it.
Old Nov 18, 2013 | 07:28 PM
  #136
CarlW's Avatar
Update:
Got the car back from the shop yesterday morning and it finally runs the way it should. Had two bad fuel injectors.
Now that my parents fixed the mechanics and having 16 days until I can get my license I finally feel safe putting a little money into it!
More updates:
I ditched the plastidip roof and just ordered a gloss black vinyl wrap and yellow headlight tint.
Better news: I bought TonyJr intrax springs so I can finally drop it! Also a stillen kit is in the works if we can get shipping settled.
The "whip" progress will now TRULY move at a steady pace as I want it done by January.
I'm excited, wish me luck.
Old Nov 20, 2013 | 07:00 PM
  #137
CarlW's Avatar
Tinted my headlights yellow after school today.
After the 1st coat :
Finished product:
Hoping to get some better pictures up tomorrow.
Old Nov 23, 2013 | 06:56 AM
  #138
coolsun's Avatar
why yellow?
Old Nov 25, 2013 | 04:55 PM
  #139
CarlW's Avatar
Originally Posted by coolsun
why yellow?
It looked good on a Porsche so I figured it would look just as good on a maxima
Old Dec 5, 2013 | 06:31 PM
  #140
CarlW's Avatar
Stillen lip kit will be here soon. Just received my 3M Vinyl wrap for the roof.
Old Dec 9, 2013 | 06:50 PM
  #141
jessi89max's Avatar
Can u take some more pix looks clean
Old Dec 9, 2013 | 06:52 PM
  #142
jessi89max's Avatar
How do you tint the lights?
Old Dec 9, 2013 | 09:31 PM
  #143
CarlW's Avatar
Thank you. I found some tint spray on amazon. http://www.amazon.com/gp/aw/d/B005Y38S3E/ref=mp_s_a_1_6?qid=1386653451&sr=8-6&pi=AC_SX110_SY165_QL70
Old Jan 22, 2014 | 06:07 PM
  #144
CarlW's Avatar
Old Jan 22, 2014 | 06:15 PM
  #145
chrome91's Avatar
cant believe im saying this but that green looks good
Old Jan 22, 2014 | 07:18 PM
  #146
CarlW's Avatar
Thanks! I think we're the only two to think so.
Old Jan 23, 2014 | 10:24 AM
  #147
1990se5speed's Avatar
i got the timing belt, tensioner, thermostat, water pump, trans fluid changed, control arms/tie rods/ball joints replaced, lowering springs put on, and a bunch of other stuff for about $1000 cash from a backyard mechanic a guy on the site here knew.
going that low is up to you, i liked it but then again i live to own oddball vehicles and slam them not caring about function persay.
That guy robed you that much for that doing suspension on these cars is easy
Old Jan 23, 2014 | 05:55 PM
  #148
chrome91's Avatar
years ago that guy did my timing belt, water pump, AND all the suspension stuff for $1000. i checked at work how much just the timing belt and water pump pays on a 3rd gen VG and it came out to over $1000 alone
Old Jan 23, 2014 | 05:56 PM
  #149
chrome91's Avatar
is it straight paint or vinyl wrap?
Old Jan 24, 2014 | 07:47 AM
  #150
CarlW's Avatar
Everything but the roof is plastidip. The roof is vinyl wrapped black. I just got it back from the shop yesterday so hopefully I'll get some pictures after a good washing.
Old Jan 24, 2014 | 08:15 AM
  #151
DanNY's Avatar
Ad·min·is·tra·tor
1000 for all that work is not bad.
it wasn't just suspension...it was also the timing belt and control arms which are not easy job since the inner sleeve of the control arm bushing usually gets rusted on the stud.
and FYI...doing struts on 3rd gens are NOT an easy task.
i'll do 4th gen struts and springs all day before i'll do a 3rd gen one. on the rears..gland packing nut..removal of entire lower spindle...total PITA.
Old Jan 24, 2014 | 03:05 PM
  #152
chrome91's Avatar
yep, i remember him saying the rear struts were miserable. best $1000 i ever spent lol
Old Oct 10, 2014 | 04:44 PM
  #153
CarlW's Avatar
RIP
Old Oct 10, 2014 | 04:55 PM
  #154
chrome91's Avatar
bruuuuutal, dont know how you can see your own vehicle at the junkyard. accidentally ran into my Hardbody at the junkyard and literally cried for the first time in years seeing it all smashed up and stripped
Old Oct 10, 2014 | 06:06 PM
  #155
ac max 92's Avatar
What happened Carl? Was the car not salvageable? That's ashame to see bud as i know you obviously put a fair bit of work into it and it didn't seem that long ago you looked so forward to driving it once you got your liscence. You also could have parted out alot of good parts here.
Old Oct 10, 2014 | 10:40 PM
  #156
Hectic's Avatar
This was my solution.
OP: That blows seeing your car at the junkyard. Happened to me once, although it was a car I bought for $300 and sold for $800 a month later, so there wasn't any emotional attachment there. Saw it at the yard a couple months after selling, bought a few nice parts off it which felt a little weird considering the car was mine..
Old Oct 17, 2014 | 08:55 PM
  #157
CarlW's Avatar
Like a fool I ran the car out of oil. Car was trashed but I got a few of the parts off of it
Yeah it did suck seeing the car at the junkyard.
Old Oct 18, 2014 | 05:53 PM
  #158
maxima278's Avatar
Funny after owning 80 cars in my life I only have two confirmed dead.. neither one I had to see though. Both were 4th gen maximas. One of them was wrecked two weeks before I inquired about buying it back, the other was sold to a former coworker and later burned to the ground in his driveway. Oddly enough, with full coverage on a car with 325k... still sad though.
tarun900
19
Dec 20, 2021 06:57 PM
jerrod99_se-l
Sep 25, 2015 03:02 AM
Socalstillen
Sep 20, 2015 11:46 PM
JoelP
Sep 19, 2015 01:08 PM
