Power steering problem video
Old Jun 22, 2013 | 04:13 PM
TonyJr's Avatar
Help
Old Jun 22, 2013 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
you need to bleed the air out of the power steering system...
Bleeding procedure:
1. Raise front of vehicle until wheels are clear of the ground
2. With engine off, add fluid into tank to specified level, leave the cap off..then turn steering wheel quickly from left to right about 10 times,lightly touching the steering stoppers..repeat procedure until fluid level stops going down.
3. Start engine, then repeat step 2 with the engine running.
Old Jun 22, 2013 | 04:31 PM
TonyJr's Avatar
Thanks I was hoping that was the problem
Old Jun 24, 2013 | 12:38 PM
TonyJr's Avatar
It didn't work. I'm starting to believe that power steering pump is going bad. What do you think?
Old Jun 24, 2013 | 01:00 PM
Greeny's Avatar
¯\(°_o)/¯
Replacing the pump would be the next logical step...
Old Jun 24, 2013 | 01:12 PM
TonyJr's Avatar
Would a worn out belt cause this problem? It only happen when I'm doing a u turn or when I turn steering wheel on a complete stop.
Old Jun 24, 2013 | 04:56 PM
TonyJr's Avatar
Found the problem. The damn power steering belt.
Old Jun 24, 2013 | 04:58 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 10, 2013 | 11:30 PM
Maxtastic GXE's Avatar
Originally Posted by Greeny
MAXSE5SPD
Sep 17, 2022 04:00 AM
pkfinn
Jan 3, 2016 02:55 PM
intimidator
Sep 5, 2015 07:23 PM
coasterswim
Sep 2, 2015 07:43 AM
hydriplex
Aug 28, 2015 02:13 PM
