92 ve30de misfire
Old Jul 16, 2013 | 02:29 PM
twiztid541's Avatar
92 ve30de misfire
my 92 maxima misfires in the top left I changed sparkplugs rearranged the coils and it still misfires in the same one... imma bout to spend a grip on injectors hoping that's whats wrong. it holds back power and sometimes it wont even jump over 3500 rpm just cuts out. any other ideas???????
Old Jul 16, 2013 | 04:48 PM
TonyJr's Avatar
Sound like a injector. Did you check to see if you have spark thur the wire?
Old Jul 17, 2013 | 01:05 AM
jdcorr918's Avatar
Check the power transistor too. Will give the same symptoms - misfire that does not move cylinder despite swapping plug and coil.
Old Jul 17, 2013 | 06:22 AM
shiloh51933's Avatar
Throwing parts at her will only thin out your wallet...you need to run some diagnostics on her. Is the cylinder getting good fuel/spark? Does it have good compression? Swapping the coil packs out was good but you need to go further. You don't want to buy an injector if you don't need one. You could have a bad lifter/valve/cam... Did you atleast ohm out the injectors?
Start doing your research...there's plenty of info right here on Maxima.org.
Old Jul 17, 2013 | 08:23 PM
twiztid541's Avatar
Ya I did a Lil playing around even bought Whole coil setup when I changed spark plugs
Old Jul 25, 2013 | 07:54 AM
twiztid541's Avatar
Can I check the maf by disconnecting the harness? If not does anyone know where to snag a cheap one? So that I can test it or atleast have an extra.
Old Jul 25, 2013 | 07:57 AM
twiztid541's Avatar
And what's ohm?
Old Jul 26, 2013 | 12:59 PM
And what's ohm?
Ohms is Resistance...voltage cause current to flow in a closed circuit, the components of that closed circuit are the load/resistance. Voltage equals current(amperage) x resistance(ohms). E(voltage)=IR(current x resistance) or 12v=.5amps x 24ohms
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
