my parking lights don't work
Old Aug 4, 2013 | 03:40 PM
91maxima_owner's Avatar
I was dimming my dash lights the other day and now my dash and parking lights do not cone on. I checked the fuses and in need of help.
Old Aug 4, 2013 | 08:58 PM
Chris Gregg's Avatar
Get Off My Lawn
Maybe switch.
Have you checked your brake lights? As I recall, it they go out, so do your dash lights. Can't recall any connection with parking lights.
Old Aug 4, 2013 | 10:19 PM
Pearl93VE's Avatar
I can has?
Originally Posted by Chris Gregg
Maybe switch.
+1. Check your stop lamp fuse. It will make the gauge cluster, front parking, and brake lights all go out. Probable cause on this is a bulb shorting out on one of your tail lamp circuit boards. The boards can be had from the dealer for pretty cheap (<$15) and Napa as well.
Old Aug 7, 2013 | 05:37 PM
GRNMAXDMON's Avatar
If only your headlights stay on and nothing else then it's your TCU(Timing Control Unit). This is either in front or behind the Anti-theft module under your dash on driver side. Just remove the panel under the steering wheel close to your knees and look for a small white box. Open it and its your TCU. Get that at your local junkyard and all your lights will come back on or just fix the circuit board. Good Luck.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
