Pitted Coolant Pipe
Old Sep 2, 2013 | 03:38 PM
tennisbike's Avatar
Pitted Coolant Pipe
Hello,
I have a 93 Maxima that I am in the process of replacing water pump/thermostat and timing belt/tensioner. During the process I found the coolant pipe on top pitted badly. Being me, I started scraping clean the surface and scraping off the soft white stuff. Before I know, the surface started looking like the crater filled moon.
I am thinking that I can clean it up better and put some QuickSteel epoxy putty on it. Getting it to shape nicely by grinding sanding before putting the hose back on.
I would love to hear any other ideas.
Cheers,
Old Sep 2, 2013 | 03:46 PM
James92SE's Avatar
2 VE's are better than one!
I've noticed that more often than not on my cars and other cars I've worked on over the years. I always just scrape all the crap off (exposing the craters) and leave it be.
Old Sep 2, 2013 | 06:50 PM
chrome91's Avatar
i would just clean it up, glob a bunch of JB weld on the pitted areas, let it cure for 24 hours, then sand the JB weld down smooth
Old Sep 2, 2013 | 07:32 PM
Hectic's Avatar
This is probably why the thermostat housing is now included with new VQ thermostats. Might be a decent idea to replace it with at least a nice used one, you wouldn't want chips breaking off, circulating in your cooling system.
Old Sep 2, 2013 | 07:37 PM
Maxpwer's Avatar
No turbo, no care!
Any epoxy and sanding is going to take a lot of time, effort and relative cost for virtually no benefit. I've seen this same problem on many VGs, yet I've never seen one fail even with 300k+ miles. Since aluminum has a large thermal expansion ratio, and your epoxy may not be impervious to coolant, your repair might not be a permanent or even a long lasting one.
If you really feel like you can't leave it alone, coat it with some gasket maker. It's cheap, fast/easy and flexible enough to remain bonded with the aluminum while tough enough to prevent corrosion and improve the hose's seal at the same time.
Old Sep 3, 2013 | 06:44 AM
shiloh51933's Avatar
You were taking the proper steps by actually cleaning parts unlike most auto owners. I'd either finish cleaning for reassembly(shouldn't leak) or replace with new/new used if your planning to restore entire Maxima.
Old Sep 3, 2013 | 08:48 PM
krashkid0305's Avatar
I cleaned all the powder off w/ a scotch bright disc on my die grinder and painted it w/ engine paint (alil over kill but it was what was in arms reach lol) haven't had a drop of coolant since
Old Sep 4, 2013 | 06:57 AM
Sounds good...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Quickywd01
Sep 21, 2016 09:36 PM
