need a answer
Old Oct 26, 2013 | 01:10 PM
maxi91's Avatar
need a answer
Where is the ecu located at?
Old Oct 26, 2013 | 03:33 PM
Greeny's Avatar
¯\(°_o)/¯
inside the front left tire
Old Oct 26, 2013 | 03:45 PM
Boule's Avatar
http://forums.maxima.org/3rd-generat...der-links.html
http://forums.maxima.org/3rd-generat...89-maxima.html
those links should help you in some way
Old Oct 26, 2013 | 04:02 PM
chrome91's Avatar
on the search function where the topic has been covered many times
Old Nov 11, 2013 | 10:05 AM
CMax03's Avatar
under the fwd center console/radio....
Old Nov 11, 2013 | 05:39 PM
ujm's Avatar
ujm
Old Nov 12, 2013 | 07:21 AM
shiloh51933's Avatar
Behind the stereo under dash...you should invest in a factory service manual or atleast a Haynes/Chilton repair manual.
Old Nov 18, 2013 | 03:17 PM
GluteusMaximus's Avatar
LOL that is hilarious. No wonder I couldn't find mine, I always thought it was bolted to the crankshaft.
In all seriousness, it is on the floor behind the center console. There are two plastic trim panels on either side. If you want access to the LEDs and the control screw, take off the passenger side panel and if you want to access the ECM harness do the driver side panel.
One phillips head screw and one plastic pop rivet and you're there.
doctorpullit
Mar 29, 2016 11:08 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
lrb6805
Sep 24, 2015 05:03 PM
msellas
Sep 23, 2015 09:16 PM
Keyno McMike
Sep 21, 2015 07:18 AM
