Bleeding cooling system
remove the rad cap, hold the engine at 2500rpm with the heater set to full hot. wait until the thermostat opens, the coolant level will drop, top it off and thats itif for some reason thats not working, you can try jacking up the front end to get the air bubbles up faster. sometimes removing one of the heater core hoses until coolant comes out of it has worked for me too
If you have the gxe there is an 8mm bleeder screw on the top right of the upper intake manifold. Take the bleeder screw out and slowly top up your coolant through the radiator when you have the car idling up to temperature until you see all the air bubbles are gone from the bleeder and it's running solid coolant then replace the bleeder screw.
tarun900
19
Dec 20, 2021 06:57 PM
