transmission studs on bell housing
i took this engine and transmission out together on 1993
its been 6 months since i got back to this project.....when i attempted to put
the transmission back onto the new engine i cannot see or remember where the two lower stud bolts on the bell housing connect to?
everything else fits no problem flywheel,torque converter,even the cover plates....
since the two studs are on the lower part of the transmission bell housing,could they be for a mount?
i am missing something and i am stuck........
i knew i should have taken pics but i didnt...ANYONE have a pic or schematic of this section of the transmission to engine.
the manual i have is garbage,but i dont see where this attaches to?????????
any help please,thanks!
rolf morrow
morrow firearms
rolf morrow
morrow firearms
I'll have to look for a picture but hopefully my description will jog your memory. There are two metal brackets that bolt to either side of the engine on the lower, trans side. They bolt to the block with 2 (on each side) short but thick bolts (like 10 or 12mm thread, but only about an inch long) and they each complete the bottom half of the trans frame. Each has a hole that accepts the lower studs coming from the transmission.
mounts lower trans housing
i really appreciate the help and thanks for taking the time to respond!
pretty sure you are right,took apart and did take pic...dumb move.
from what i have found in the box of mounts,you definately
sparked my memory,makes sense,cant believe i didnt see it.
going to save me big time.
thanks again,
rolf morrow
morrow firearms
thanks again,
rolf morrow
morrow firearms
Finished NEW Engine Install EXCEPT............
engine and transmission done.
i cannot find where one hose on the throttle body goes?
![transmission studs on bell housing-throttle.jpg](https://maxima.org/forums/attachments/3rd-generation-maxima-1989-1994/5749d1482451241t-transmission-studs-bell-housing-throttle.jpg)
PLEASE HELP
almost done...............
does ANYONE have a PIC of their Maxima Throttle body with all the hoses connected that
they can post for me?
i am stuck and cant go further.......
PLEASE HELP
new help with new throttle body
Attachment 5749
PLEASE HELP
Attachment 5749
PLEASE HELP
Vacuum Connection on Transmission SE 1993?
found another open vacuum connection on top of transmission bell housing?
looks like a 1/4- 3/8 inch connection........
what is it?
i completely removed old engine and transmission and replaced with another
but i am now down to final last connections.
please help since i cannot post new i have to utilize this way to get answers,THANKS!
what is it?
Throttle Body PIC NEEDED Please Help
[QUOTE=morrowfirearms;8946486]engine and transmission done.
Attachment 5749
PLEASE HELP
Attachment 5749
PLEASE HELP
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
That barb under your throttle body runs to the smaller port on the charcoal canister that's under the battery/drier area of your engine bay.
I'm not sure what you mean by the other vacuum connection on top of bellhousing - got a pic?
That looks like an autotragic transmission to me so I can't say for sure but I suspect it may just be a vent port. The manual transmissions have a vent port on top. Neither of my VE's are autotragics so I can't confirm for you
great forum
the help i have received on this forum is great!
i have used other forums and they are a joke alot of the time,but this maxima forum has alot of very helpful people!
thanks again,
morrow firearms
thanks again,
morrow firearms
06-06-2017 02:01 PM
Pied
09-26-2015 03:29 PM
