do these rims fit?
Old Feb 9, 2014 | 07:48 PM
TonyJr's Avatar
do these rims fit?
Lexus IS 300 (2000+) - 17"x7" rims - 12x1.5 lugnuts - 60.1mm centerbore - High offset
Old Feb 9, 2014 | 07:51 PM
TonyJr's Avatar
I believe this is our factory rim size of it helps.
Nissan Maxima (1989+) - 15"x6" rims - 12x1.25 lugnuts - 66.1mm centerbore - High*offset.
I do have ebiach lower spring 1.2" drop
Old Feb 9, 2014 | 07:52 PM
TonyJr's Avatar
All I know is there both the same lug pattern
Old Feb 9, 2014 | 09:15 PM
No good. The center bore is too small.
Old Feb 10, 2014 | 12:26 AM
TonyJr's Avatar
Damn
Old Feb 10, 2014 | 03:56 AM
CMax03's Avatar
Bolt pattern is the same....5-114.3 but you can have a machine shop machine the centerbores to 66.1 mm if you really want them!!!!! That might cost $20 per wheel!
Old Feb 10, 2014 | 04:36 AM
TonyJr's Avatar
Man that sucks. I got to think about it. I'm just tired of my 4th gen maxi mnemonic a wheels
Old Feb 10, 2014 | 04:37 AM
TonyJr's Avatar
Maxima
Old Feb 11, 2014 | 02:08 AM
TonyJr's Avatar
Would a 2004 maxima rims fit our 3rd gen?
Specs
Offset: 42mm
Bolt Pattern: 5-114.3
Tire Size: 225/55-17
2004 maxima rims
Old Feb 11, 2014 | 02:18 AM
TonyJr's Avatar
Or would the 2010 rims fit my 1992 ve
Old Feb 11, 2014 | 07:39 AM
Yes and yes
Old Feb 12, 2014 | 01:30 PM
TonyJr's Avatar
Ok so I bought the 2004 maxima rims for my 3rd gen without tires. For $220
My new ? Is what size tires should I get with my car being drop 1.2".
?/40/17
?/45/17
Old Feb 12, 2014 | 01:35 PM
Amerikaner83's Avatar
225/45/17 would work just fine
Old Feb 12, 2014 | 02:39 PM
TonyJr's Avatar
No rubbing on fender with a 1.2" drop
Old Feb 12, 2014 | 04:34 PM
Tiniform's Avatar
I run 225/45/17 on 2" dropzone springs with no issues
Old Feb 13, 2014 | 06:22 AM
TonyJr's Avatar
Sorry but the rims I'm buying have 215/40/17. Would this work?
Old Feb 13, 2014 | 08:13 AM
those are smaller, so yeah they'd work. But you said above you bought them without tires, so you could put 225/45 on the wheels
Old Feb 13, 2014 | 08:57 AM
Jacobaudi's Avatar
We'll for u guy that wants wider tires I got 245/45/18 on my 3rd gen of course u have to get the back fender rolled
Old Feb 13, 2014 | 12:36 PM
TonyJr's Avatar
Thanks for the help guys . So I chose the 215/45/18 rims
https://i.imgur.com/CvEponQ.jpg
Old Feb 13, 2014 | 03:37 PM
CarlW's Avatar
I like it
Old Feb 13, 2014 | 03:40 PM
skinny
Old Feb 14, 2014 | 02:42 AM
TonyJr's Avatar
Originally Posted by CarlW
I like it
Thanks I like it too
Old Feb 14, 2014 | 02:49 AM
TonyJr's Avatar
https://i.imgur.com/RE07TtU.jpg
https://i.imgur.com/i2PIToh.jpg
Old Feb 19, 2014 | 08:50 PM
CarlW's Avatar
I didn't want to make a whole new thread for this so here it goes.
I'm looking at these wheels but I'm not sure if they'll fit.
Specs:
Front - 18x8.5 +30
Rear - 18x9.5 +35
The wheels look good but are the rears too wide even if I roll the fender?
Old Feb 20, 2014 | 01:46 AM
TonyJr's Avatar
Specs:
Front - 18x8.5 +30
Rear - 18x9.5 +35
My rims I just bought are 18" n they fit perfect. Plus my car has ebachi springs 1.2" drop. But the lowest I would go is +40
Old Feb 20, 2014 | 04:10 AM
CarlW's Avatar
So they'd fit?
Old Feb 20, 2014 | 07:22 AM
DMad8724's Avatar
I'm Sorry, But CARLW will you stop being such a n00b??
it's obvious you're 16 after reading time and time again that you need a '4 inch drop' and you plastidipped your car super blue and now you need to run 10" wide wheels on your 3RD GEN. maybe you should calm down with all the modifications you're doing and actually put some thought into them which will save you money/headaches in the long run
and just so you know I'm not entirely just being rude: those 18x8.5s will fit. That's literally about as big as you can go, tho. the 9.5s will not fit. You really don't want anything wider than 8, but if you have to 8.5 should be the maximum width
Old Feb 20, 2014 | 12:22 PM
TonyJr's Avatar
I hope your joking about him plasticdipp his car blue lmao sooo rice. 4" drop smh comon bro.
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Pied
Sep 26, 2015 03:29 PM
