Need help with airbag
Old Feb 23, 2014 | 08:01 PM
Jacobaudi's Avatar
So this morning I went into my car and started it up and I see my airbag light flashing slowly do anybody know what is causing this?
Old Feb 23, 2014 | 09:28 PM
DennisMik's Avatar
There are several possibilities. You could try re-seating the connectors on the control unit and safing sensor that is under the console.
You could also run the self diagnostic and count the blinks of the light. I'm not sure if the 7 blinks you get are the same as 7 blinks from the self diagnostic.
For the self diagnostic procedure, it starts on page 95 in section BF of the service manual.
Location of the air bag system components is on page 86 of the same section.
http://boredmder.com/FSMs/Nissan/Maxima/1994/BF.pdf
Old Feb 24, 2014 | 12:09 AM
Levsimus's Avatar
Whatever you do, if you mess around with the airbags whilst chasing down the issue, even just unplugging and replugging something, disconnect the battery. Anything airbag/SRS related it's best to disconnect that battery!
You do not want to inadvertently detonate an airbag directly into your face. It'll ruin your day with a quickness. It's not very common even if you ignored all safety precautions, but it does happen and guys have been seriously injured and even killed!
Old Feb 27, 2014 | 11:12 AM
bhunter's Avatar
You can try a reset procedure, I did a write up a few years ago. It's here if you search.
If you have a real issue the reset won't fix it, but if it is just a glitch it will.
Old Feb 27, 2014 | 11:36 AM
Jacobaudi's Avatar
Originally Posted by bhunter
You can try a reset procedure, I did a write up a few years ago. It's here if you search. If you have a real issue the reset won't fix it, but if it is just a glitch it will.
yes I did a reset and it worked thanks guys
Old Mar 5, 2014 | 09:24 AM
Chris Gregg's Avatar
Get Off My Lawn
I h e a complete airbag system. If you find you need anything, let me know. I even have the harnesses.
ThomasofSodor
Mar 22, 2018 08:18 PM
ToTheMax305
Sep 23, 2015 09:11 PM
Colossus
Sep 9, 2015 05:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
