Plastic Spool for Power Window Broken
Old Jan 21, 2002 | 03:28 PM
seawolf14's Avatar
Front, passenger side window is broken. Took apart the door and saw the plastic spool is broken. I have searched the board for info and it was of great help. Just curious if you can purchase the plastic spool itself? When you buy the regulator, what pieces come with it?
Thanks for your help.
Old Jan 21, 2002 | 03:38 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Plastic Spool for Power Window Broken
the regulator is the entire assembly minus the motor.
i don't think they sell the wheel/spool separate.
Old Jan 21, 2002 | 04:25 PM
pood's Avatar
Power window
I've worked on the regulators and it looked like it would get quite involved to unwrap the cable and get it back together. When I had mine apart I used silicone grease to lube the tracks and sprayed the area where the window slides with silicone spray. It seems to make the regulators last longer and it won't cuase the plastic to deteriorate. I've got the regulators, cable spools and documentation if your interested.
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
