turbo for sale ?
Old Jun 26, 2014 | 12:23 PM
TonyJr's Avatar
turbo for sale ?
I met someone who is selling a turbo kit for a 95-03yr maxima. Can I use any of his setup for my ve?
Turbo maxima
Parts that are left :
Turbo kit 1200
440 injectors 180
Emanage blue 180
Emanage ultimate 500
Innovate wideband with 2 sensors
Old Jun 27, 2014 | 04:38 AM
James92SE's Avatar
2 VE's are better than one!
You could use the injectors, the innovate wideband, and the actual turbo. The emanage stuff I believe is universal so you could probably use it too. Anything as far as the "kit" - in terms of physical piping - you will not be able to use and will need to fabricate your own or have somebody fabricate it for you.
Old Jun 27, 2014 | 05:48 AM
DanNY's Avatar
Ad·min·is·tra·tor
injectors are probably not going to be plug and play.
don't get the emanage unless you're willing to learn how to wire it up on to your ECU..and no...NO ONE..(not even GReddy) can help you or teach you how to wire it up to your car.
just to put this out there...
1 - no company out there is going to make a bolt on turbo kit. if there's one the 3rd gen turbo community would be a lot larger.
2 - there's no short cut if you want to run a turbo...simple as that. you want to play..you gotta pay.
3 - bolt on kits from other car will NOT fit on your car without at least SOME customization so stop looking at the "kits" from other cars and dreaming.
Old Jun 27, 2014 | 10:06 AM
James92SE's Avatar
He's got a VE, which has identical injectors to the VQ so the injectors should be plug and play.
Old Jun 27, 2014 | 11:47 AM
DanNY's Avatar
Ad·min·is·tra·tor
oh? same harness/plug too?
interesting...
Old Jun 27, 2014 | 01:41 PM
TonyJr's Avatar
Yes I do I just bought the injectors.
The turbo project has begun.
Old Jun 27, 2014 | 05:21 PM
Maxpwer's Avatar
No turbo, no care!
Originally Posted by TonyJr
Yes I do I just bought the injectors. The turbo project has begun.
Are the injectors top or side feed? Not all VQs used side feed injectors.
Like Dan said there is nothing that comes close to a plug and play so in order to piece together your own system you are going to be knowledgable enough yourself to determine what parts you can adapt to work with your car and goals. I would recommend your next purchase be Nistune and a wideband so you can gain familiarity with their abilities and the management of your engine. This way when it comes time to tuning you aren't scrambling to learn the basics when your turbo.
BTW, buying injectors doesn't count as the beginning of a turbo project.
Old Jun 27, 2014 | 05:46 PM
James92SE's Avatar
interesting...
Yep, totally identical. The fourth gen Maxima at least. Other VQ's may be different (like Maxpwer mentioned). I always swipe easily accessible front bank fourth gen Maxima injectors at the junkyard for easy backups/spares
Old Jun 27, 2014 | 07:29 PM
TonyJr's Avatar
Damn so negative. Like I said this is the start of my turbo project. First item I buy.
Old Jun 27, 2014 | 07:31 PM
TonyJr's Avatar
James I'm going to start taking them too. Tons of 4th gens at my junkyard
Old Jun 28, 2014 | 02:40 PM
DanNY's Avatar
Ad·min·is·tra·tor
not negative...just setting your expectation on what you'll need to get and do. can't sit there posting and asking questions on stuff you saw off ebay thinking that you might get it to work...its just not going to happen.
you know how many guys we see on here post they are going turbo and thinks that getting a wastegate or a boost gauge is the start of their build??
Old Jul 17, 2014 | 11:28 PM
Maxpwer's Avatar
No turbo, no care!
Were the injectors you bought top feed or side feed?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
maxima-junky
Oct 7, 2015 06:13 PM
09maxshawn11
Sep 30, 2015 10:28 AM
