91 Maxima SE - Bad Thermostat?
Old Dec 1, 2014 | 11:44 AM
Mosin Nagant's Avatar
As the title say I believe my Maxima has a bad thermostat. When I let the car idle and warm up the temperature goes up to and stays at normal operating temperature and my heater pumps out some heat. When I drive down the highway the temperature gauge bottoms out and I get little to no heat. The colder it is outside the worse the problem is. I can drive down the highway for an hour then stop and let the car idle again and it eventually goes back up to normal operating temperature. My theory is the thermostat is stuck open and the cold air hitting the radiator when I drive down the highway is causing the anti freeze to get too cold. Does this make sense or does anyone think it could be something else? If I have to replace the thermostat how difficult of a job is it?
Old Dec 1, 2014 | 12:26 PM
Levsimus's Avatar
Thermostat sounds like a safe bet! Thermostat is KIND of a pain, but totally doable. I admit I'm not a good source of how because I did mine when I had the motor out, but I hear it's a bit cramped. VG 30 has it in the right side of the engine bay, follow the upper hose, Thermostat is behind the cover it attaches to, if I recall.
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
Superbform
Aug 11, 2015 08:10 PM
acw
Aug 7, 2015 04:20 PM
