Is it possible to swap a later model 6-speed transmission into this car with the vg30. If it is possible let me know of what year and model car I can get a transmission from to get.
nope, only other trans you can use is a VE30DE manual trans and you have to swap over axles and other stuff. VQ transmission wont bolt up to a VG
Quote:
Not without an adapter plateOriginally Posted by chrome91
Quote:
which? VE manual trans im pretty sure you dont need an adapter plate. VQ trans on a VG i dont know how you would make the axles and stuff work even past the adapter plate issueOriginally Posted by CMax03
I'm being a smart a$$! But if you had an adaptive plate between the VG and the 6 spd M/T....I' m sure the VE30 and VQ inboard driveshaft are the same splines but the different length unsure but The Driveshaft Shop can build Hybrid axles! Anyway I found 3 M/T in the junkyard yesterday.... VG30 3rd Gen, VQ30 4th Gen, and 5th Gen. I'm eager to swap the 4th to a M/T but I like cruising that A/T alot....
