water on passenger side carpet
Old Feb 10, 2015 | 04:36 AM
TonyJr's Avatar
As I was vacuuming my car and moved the passenger side floor mat and notice it was wet only under floor mat towards the lower sections of floor mat. every happen to you
Old Feb 10, 2015 | 06:07 AM
James92SE's Avatar
2 VE's are better than one!
What do you mean by the "lower sections of the floor mat"?
Old Feb 10, 2015 | 08:02 AM
TonyJr's Avatar
I'll take a pic
Old Feb 10, 2015 | 11:13 AM
TonyJr's Avatar
Nevermind it looks like it's coming out of the heatercore
Old Feb 10, 2015 | 11:20 AM
James92SE's Avatar
I was going to say your only culprits would be heater core or evaporator box. Though I assume you're not running your AC in early February. But the "lower sections" wording confused me.
If it's your heater core that sucks because that's not a fun job. The whole dash has to come out to do the heater core. I've had my dashes out half a dozen times so they're fairly easy for me now but still no fun
Old Feb 10, 2015 | 01:07 PM
DanNY's Avatar
Ad·min·is·tra·tor
don't let it drip for too long...the ECU might get wet from coolant.
Old Feb 10, 2015 | 02:35 PM
Darkwing48's Avatar
To avoid that, I did a heater core bypass, since I did not have the time to replace the heater core. Before then, I became too familiar to the smell of coolant, and I put towels on top of the ECU.
Old Feb 10, 2015 | 02:45 PM
TonyJr's Avatar
Doing bypass tomorrow won't need ac till june. And I need to replace my Crack dash and guage. I don't think it's hard at all just time consuming.
Old Feb 10, 2015 | 03:02 PM
James92SE's Avatar
What do you mean won't need AC till June? Your AC is irrelevant to your heater core.
Actually the dash is the easy part. The extra irritating part is that big center support beam needs to come out (or at least loose enough to move) as well as the much of the crap attached to it
Old Feb 10, 2015 | 03:20 PM
TonyJr's Avatar
O damn for real. Other them the nissan dealer where should I buy a heater core.
Old Feb 10, 2015 | 03:58 PM
James92SE's Avatar
What I've been doing lately is getting part numbers from Rock Auto then buying the same part on eBay for cheaper
Old Feb 10, 2015 | 04:02 PM
James92SE's Avatar
Here's an OEM for cheap
http://pages.ebay.com/link/?nav=item...d=151576239665
Old Feb 10, 2015 | 07:05 PM
maxinout93's Avatar
heater core time, I got an oem one from the junkyard that was in pretty good condition. I never did a heater core job in my life but the price the mechanics were charging here was outragous and I needed heat for the crazy winters here. So i took the time to remove the dash and everything attached to it. With the help of the org, I managed to do it in less than a day. I didnt have to remove the steering wheel or the center beam. Saved myself about $600.
The Wizard
24
Oct 1, 2015 08:47 PM
RWCreative
Sep 21, 2015 11:01 AM
Bonka
Sep 14, 2015 11:18 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
