Radiator?
Old May 13, 2015 | 05:20 PM
Starrider's Avatar
Radiator?
Hi Guys...
Seems i need a new radiator...any good vendors recommended appreciated. This is for a 94 GXE v6.
Wow have i been out of the loop...just found out radiators are made of plastic?
Old May 13, 2015 | 06:10 PM
ac max 92's Avatar
Only the top and bottom are plastic but you can get all aluminum rads at a higher cost. Koyo rads are pretty good as a replacement to oem. Check either some of the vendors here on the org. or ebay and shop around for a good price but if im not mistaken there's a vendor here on the org that sells rads at a good price.
Old May 13, 2015 | 08:09 PM
Starrider's Avatar
Thanks ac 92 max...Kayo. I saw their site...good to know someone referred them.
When i looked at the old radiator...only saw some rusting on the metal top bracket near center radiator cap. Temperature doesn't indicate over heating...and when i check the radiator cap on a cold engine...water always filled to the top.
Old May 13, 2015 | 08:32 PM
chrome91's Avatar
Koyo or Mishimoto all-metal
Old May 13, 2015 | 09:31 PM
Starrider's Avatar
Thanks chrome91.."Koyo or Mishimoto all-metal"...
Old May 14, 2015 | 03:44 PM
ac max 92's Avatar
Usually if the rad itself leaks you will see antifreeze along the bottom or top ridge where the crimping is (looks like a bunch of teeth) it will usually start as a minor leak before it gets worse but if it's just a little rust your seeing it could just be from moisture after rain i wouldn't bother changing it unless it is leaking for sure. The oem calsonic rads are the best but i guess for what an aftermarket rad is worth and if your not on a tight budget then go for it.
Old May 14, 2015 | 09:17 PM
DennisMik's Avatar
and when i check the radiator cap on a cold engine... water always filled to the top.
If the radiator is always full, then I would have to say that you don't have a leak. Is the level in the overflow tank also good and not going down?
I'm trying to imagine what is rusting. The only thing I can think of is the metal "fingers" that crimp the plastic tank onto the core. I don't know what kind of metal is used for those fingers.
Old May 26, 2015 | 05:49 PM
Starrider's Avatar
Thanks ac max 92
DennisMik Yes the metal strip or crip along the plastic top tank show some rust. Radiator cap open on cold engine always to the top level ...however i do fill the overflow tanks at times really don't keep track of it.
Car doesn't overheat even when ac is used?
Its probably as ac max 92 describes...just seeping at first.
Thanks Guys!...
Old May 26, 2015 | 06:08 PM
DanNY's Avatar
Ad·min·is·tra·tor
i would just leave it until you start to see a more significant leak or a drop in coolant level.
how old is your timing belt? possible the water pump is slowly leaking at the weep hole?
IMO the best is the OEM radiator. i purchased an Koyo...looked inside and was not impressed. you look inside your calsonic OEM and it's perfect in there.
Old May 26, 2015 | 06:20 PM
ac max 92's Avatar
+1 I agree that the oem are the best. Especially after over 20 years with no leaks vs. Aftermarket. If he can find a calsonic at his local yard that would be good but otherwise koyo seems to be the better aftermarket coice.
Old May 26, 2015 | 08:18 PM
Starrider's Avatar
The car bought new in late 94...has about 130k on speedo. The guys at the shop wonder why i don't opt for a new car? Timing belt was change at 50k miles, recently new struts front and back, rebuilt rack pinion steering, brakes, water pump still original ( trans may be slipping)...and paint still great...only three door dings. Oh and engine still runs strong.
Old May 26, 2015 | 08:55 PM
chrome91's Avatar
mileage isnt the only thing for timing belts though, around 6-7 years of age they can get cracked and brittle and you still need to change it no matter the mileage. or at least take off part of the timing cover and inspect it
Old May 26, 2015 | 09:02 PM
cdoublejj's Avatar
one thing i envy about the earlier gens is the all aluminum rads you guys can get 5th gen and up doesn't have squat for all aluminum rads.
Old May 26, 2015 | 09:46 PM
5th gens can use 4th gen rads.
6th gen aluminums are available from Mishimoto.
Old May 27, 2015 | 03:31 PM
Starrider's Avatar
Ok...Thanks chrome91...
Old May 29, 2015 | 09:34 AM
cdoublejj's Avatar
does any one sell performance and or all metal 4th gen rads? does the 6th gen rad fit too? i'd like to get all metal and preferable a little better cooling because i'd like a little extra cooling for forced induction.
Old May 29, 2015 | 03:54 PM
ac max 92's Avatar
Install an external cooler. You could also use some hyper-lube coolant additive.
Old May 31, 2015 | 07:43 PM
cdoublejj's Avatar
EXTERNAL cooler? you mean like an oil cooler and oil cooling additive.
Old Jun 1, 2015 | 11:17 AM
ac max 92's Avatar
Yes. The external cooler will help with the transmission and the additive is supposed to help run the engine a little cooler. I personally haven't used the hyper-lube additive but I have installed an external cooler for the trans.
Old Jun 1, 2015 | 05:53 PM
DanNY's Avatar
Ad·min·is·tra·tor
actually the OEM nissan radiators are pretty efficient for the maxima. I believe the Z31T guys or it might be the Z32TT guys running them.
i have the koyo 2 core and no issues with FI and cooling. temps are always where it should be in the hottest temps with the AC running.
Old Jun 2, 2015 | 09:47 PM
cdoublejj's Avatar
is the koyo a plastic rad? i kind of wanted to go silicon hoses and all metal rad.
Old Jun 3, 2015 | 06:42 PM
DanNY's Avatar
Ad·min·is·tra·tor
i believe they have plastic and metal versions for the 3rd gens.
the all alum one you can find...but you'll need to do some digging or relocate some piping.
Old Jun 3, 2015 | 07:52 PM
ac max 92's Avatar
Vibrant makes a silicone vacume line kit which is universal silicone hoses you cut to length to replace all of your vacume lines but good luck with finding any molded silicone hoses for the cooling hoses/rad hoses. If you do happen to come across anything let us know.
Old Jun 3, 2015 | 08:12 PM
chrome91's Avatar
i did quick digging and looks like all-metal radiators for 3rd gens are next to non-existent. only hope would be to get a universal all-metal radiator and rig the fans and plumbing to fit for it
Old Jun 4, 2015 | 09:45 AM
jakeru's Avatar
I have an aftermarket all-metal radiator for mine. I believe it's all copper and brass, soldered-together construction. It's seems to be working very well to keep things cool, and has no leaks, and fit ok (not quite as good as Oem fit, but good enough to work.) I sourced it locally from an Asia importer. (No shipping costs from importer to me).
Old Jun 18, 2015 | 12:46 PM
khakuda's Avatar
Look on amazon for the one below. Do some research, but this is supposed to be made by KOYO:
TYC 1752 Nissan Maxima 1-Row Plastic Aluminum Replacement Radiator
Old Jun 23, 2015 | 12:05 AM
cdoublejj's Avatar
http://www.ebay.com/itm/161404192601?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/191154298078?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/131438937652?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/261766377524?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 29, 2015 | 10:37 PM
cdoublejj's Avatar
anyone have any thing different or better?
Old Jul 2, 2015 | 12:10 AM
CMax03's Avatar
I thought my buddy purchased a Mishimoto radiator for his 3rd Gen not to long ago...
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
