Auto to stick conversion
Old Jan 26, 2002 | 08:39 AM
pood's Avatar
Has anyone done a automatic to standard transmission conversion? Whats involved?
Old Jan 26, 2002 | 09:01 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Auto to stick conversion
Search has......
Old Jan 26, 2002 | 05:17 PM
D-sta's Avatar
I never liked the idea of this. It cost a lot of money and it most likely will not come out too well, i mean you need to definetly change the stock computer since it is programmed to work with the automatic transmission so there alone you have a couple of dollars. You also change the rythem of your engine which believe it or not does get use to. I would consider just buying a stock 5-speed maxima. Most tranny shops will tell you not to change the computer and this might work and some cars and on some it won't.
D-sta
Proud owner of VE 5-speed power
Old Jan 26, 2002 | 08:07 PM
crusher84's Avatar
An *** load of work and money. It's a far better idea to buy a 5spd and not screw with collecting all the parts and money, waiting for the mechanic to get his thumb out of his ***, and sparing the car for who knows how long. Trust me, if it were worth the trouble, we'd all do it.
Old Jan 26, 2002 | 10:09 PM
Jeff92se's Avatar
I'm needing a caw
I'd do it
Old Jan 26, 2002 | 10:24 PM
PATRICK94SE's Avatar
Re: Re: Auto to stick conversion
Originally posted by DA-MAX
Search has......
SORRY to jump in on the post but that was just to slick to ignore
Old Jan 26, 2002 | 11:55 PM
Lordrandall's Avatar
Originally posted by Jeff92se
I'd do it
Yeah, but would you buy an SUV?
Old Jan 27, 2002 | 12:03 PM
Brian_TII's Avatar
D-sta
I don't think it would be ALL that big of a deal. If you could find a 5spd that had been hit (hard) in the rear you could just swap parts until thing worked right. This wouldn't be expensive assuming you are skilled enough to do it yourself.
Personally I'm in this situation right now... my auto screwed up the other. It's started working "fine" again now... but it's on it's way out. I'm sure what I'm going to... I'm CONSIDERING the possibitly of doing a 5spd.
Old Jan 28, 2002 | 06:07 AM
nupe500's Avatar
Jedi Knight
Re: Re: Re: Auto to stick conversion
Everyone(with an automagic)..probably has thought about it before...but its just not worth it...in fact it has been done...but there were issues with if after completion......but like DA-MAX said....search button works wonders.
Old Jan 28, 2002 | 09:02 PM
Neice Anne
Search has......
See this needs to be a sticky for the asses out there who respond more rudely than this.. THIS is how you properly school a newbie on board etiquette not "YOU ****ING DUMBASS DONT EVER ASK THAT QUESTION AGAIN OR I M GONNA KICK YOUR ***! SEARCH *****!"
Old Jan 28, 2002 | 09:14 PM
Brian_TII's Avatar
The other thing is that I'm not convinced that this is ALL that bad of a swap. I mean if you have both cars... one wrecked SE 5spd and an auto... then I mean... it should only be a matter of time and effort to switch it over. It really shouldn't be expensive. Just timing consuming. I mean... realistically if you HAD to you could even swap harnesses and all... I can't imagine that it would be ALL that hard. If I could find a 5spd for cheap I would probably do it. I mean... especially in my situation where I have an extra car that I can drive while I'm working on the other one... it's just not THAT big of a deal. (Or at least it doesn't seem like it would be)
Anyway... that's my $0.02...
Old Jan 28, 2002 | 09:16 PM
Matt93SE's Avatar
STFU n00b!
if you guys will do a bit of studying on the 3rd gen, you'll notice the autos and 5 spds have a different plate welded onto the firewall.... this is probably because of the clutch pedal, and there's some other issues with the hydraulics.
the 5 spd swap has been done in a 4th gen (I saw it personally this weekend. his check engine light is constantly on due to all the loose wire connectors from the auto). but it does work.
the 3rd gen will be a lot harder because of the firewall issues.
AaronL
Aug 8, 2020 10:31 AM
Calabar
Oct 5, 2015 09:57 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
dshinn
Sep 26, 2015 08:07 PM
