93-94 vg30e injectors
Old Jun 23, 2015 | 08:58 PM
ac max 92's Avatar
Anyone know who's got the best price for the 93-94 vg fuel injectors?
Old Jun 24, 2015 | 07:32 AM
James92SE's Avatar
2 VE's are better than one!
Rock Auto has brand new Bosch injectors on close-out right now for $38 each (U.S.), don't think that price would be beatable anywhere. They're normally $100 each. Might want to jump on that.
Old Jun 24, 2015 | 07:39 AM
ac max 92's Avatar
Thanks James, I found a set of 6 reman JECS injectors that comes with flow chart for $160 U.S. How are the Bosch compared to the JECS? Both sound like good deals.
Old Jun 24, 2015 | 08:32 AM
James92SE's Avatar
I think rather than comparing JECS vs Bosch, you should be comparing used vs. new.
JECS makes the OEM injectors (at least for the VE, I'd assume they made the VG too). However, in your case, all that means is your $160 injectors are used OEM ones. That's not really saying much. "Reman" injectors are just used injectors that have been cleaned and tested for proper spec ohm-wise.
Our injectors almost universally fail electrically rather than being clogged or whatever. This means you're not really getting much benefit from rebuilt injectors in my opinion, as the most likely reason they would fail is not addressed at all by cleaning them. So if you're going with used injectors there's not really any point of paying for rebuilt (cleaned) injectors. Just get used ones at junkyards or something.
If I had to choose between 100% brand new Bosch injectors, or used OEM injectors for only $70 difference, I'd choose the new ones all day everyday.
Old Jun 24, 2015 | 11:01 AM
ac max 92's Avatar
Makes sense. Thanks
Old Jun 25, 2015 | 05:47 AM
Ray229Harris's Avatar
Thanks for the info James92.
I can't remember if i've asked *you* this, or someone else, but is there a problem with mixing brands of fuel injectors? I'm thinking they all should spray the same, right?
Old Jun 25, 2015 | 07:14 AM
James92SE's Avatar
For 160hp n/a stock purposes, I'd think you'd notice zero difference by mixing different brands of injectors. I'm sure if you flow tested them all, you might could pick out some differences - but whether or not that'd be a "problem" in a real world installed-in-the-car-and-driving-it-around scenario? Slim chance.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
ballerchris510
Sep 10, 2015 09:35 PM
