Ve turbo update 2
Old Aug 3, 2015 | 04:20 PM
  #41
TonyJr's Avatar
I would make sure they don't do that ****. I would get **** off of they did that. If I could get a copy from someone with my setup I would consider buying the cable and license. But for now I'm only buying chip plus install =$320
Old Aug 4, 2015 | 06:54 AM
  #42
TurboA32's Avatar
Why would you get mad?? You obviously don't know what your doing so that would be your best bet to just take your to a tuner.
Old Aug 4, 2015 | 08:56 AM
  #43
TonyJr's Avatar
I would be mad if a turner would not do a proper tune. Wouldn't you be mad if that happen to you
Old Aug 4, 2015 | 08:58 AM
  #44
TonyJr's Avatar
But I'm in good hands with kings performance
Old Aug 4, 2015 | 10:40 AM
  #45
TurboA32's Avatar
There's nothing wrong with what I said I think they would do lol its not improper
Old Aug 5, 2015 | 08:17 AM
  #46
TurboA32's Avatar
Originally Posted by Maxpwer
I thought all (prior to OBD 2 at least) ECUs clear their codes after being removed from their power source for a few seconds. Did you ship your ECU with a 12v battery to Australia?
Its funny that you quote me but didn't even read what I posted
Old Aug 5, 2015 | 09:42 AM
  #47
Maxpwer's Avatar
No turbo, no care!
Originally Posted by TurboA32
When they do the board install for you make sure you clear any ecu codes thats stored in your ecu before they get it because if they download the base image from your ecu (which would be the correct way to do it) and theres any codes in that ecu, when they burn that image onto the board that code will always be there and the only way to get rid of that code is to put the ecu back to stock, erase the code and download the image with no codes from the ecu and ect....so just make sure you clear any codes before you give your ecu to them
Old Aug 5, 2015 | 04:16 PM
  #48
TonyJr's Avatar
Old Aug 5, 2015 | 10:05 PM
  #49
lux97Max's Avatar
Ve turbo update 2
VTC CLACK!!! Did you try the grounding trick already?
Old Aug 6, 2015 | 01:37 AM
  #50
TonyJr's Avatar
I will try again
Old Aug 7, 2015 | 02:35 PM
  #51
DanNY's Avatar
Ad·min·is·tra·tor
nice job tony but it sounds like there's a lot of leaks. It sounds like there's an intake leak somewhere too.
is it the VTC that's making the engine sound like a sewing machine?
Old Aug 7, 2015 | 03:32 PM
  #52
TonyJr's Avatar
I had oil catch can leak, wastegate leak, turbo flange leak lol. All fixed except one.
Only 1 leak left to fix. Exhaust manifold
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
