Ve turbo update 2
Old Jul 25, 2015 | 01:39 PM
TonyJr's Avatar
Ve turbo update 2
Rain delay will finish tomorrow.
Old Jul 25, 2015 | 02:21 PM
James92SE's Avatar
2 VE's are better than one!
Is that single fan going to work as both your radiator fan and your condenser fan?
Old Jul 25, 2015 | 03:56 PM
TonyJr's Avatar
Its work for bradse92.
It will be on all the time. It cover the whole radiator
Old Jul 25, 2015 | 03:59 PM
TonyJr's Avatar
File Type: jpg
Old Jul 26, 2015 | 03:04 PM
TonyJr's Avatar
Old Jul 28, 2015 | 12:20 AM
TonyJr's Avatar
Old Jul 28, 2015 | 09:27 PM
Hectic's Avatar
You're getting there. I don't have much to add as boost isn't something I have any experience with, but looks like you're on your way. Good luck, keep making the update videos. It livens things up a bit around here.
Old Jul 29, 2015 | 12:51 AM
TonyJr's Avatar
No problem
Old Jul 31, 2015 | 06:51 PM
TonyJr's Avatar
Old Jul 31, 2015 | 08:52 PM
TurboA32's Avatar
Just finished watching your vid and I wouldn't start and run the car the way it is. You should get what you need welded done, put some exhaust paint and exhaust wrap on your feed and down pipe, make sure all wires are out of the way from any exhaust parts, get a turbo blanket for your turbo
Old Aug 1, 2015 | 02:46 AM
TonyJr's Avatar
Buying the wrap today to protect all the wires
Old Aug 1, 2015 | 02:47 AM
TonyJr's Avatar
Old Aug 1, 2015 | 02:48 AM
TonyJr's Avatar
Do they sell wrap for oil feed line?
Old Aug 1, 2015 | 07:58 AM
TurboA32's Avatar
I hope there's nothing near or touching the exhaust parts. Even with the exhaust wrap you can still melt things. It gets very very hot and don't forget the turbo blanket too but this is what I got and I just cut it in half and modified it for my application and used staples
http://www.ebay.com/itm/111441726302?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Aug 1, 2015 | 08:18 AM
TurboA32's Avatar
And you can take off the filter and use this or something like this
http://www.ebay.com/itm/321577263215?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I had the same filter your using when I had a supercharger many years ago and i just took the rubber off the filter and used it for my turbo and I cut a window screen to the size I needed it for my turbo
Old Aug 1, 2015 | 08:20 AM
TurboA32's Avatar
And your supposed to have coolant in your overflow tank you might wanna do that
Old Aug 1, 2015 | 08:29 AM
TurboA32's Avatar
Your vacuum seems good but your air/fuel is lean at idle should be 14.xx to 15.xx at idel but are you running a z32 maf on stock ecu without a piggyback in that last vid with the car running?
Old Aug 1, 2015 | 09:40 AM
TonyJr's Avatar
still on stock ecu and injectors. I have 370cc and a z32 maf sensor I plan to install in 2 weeks when nistune is in then get a tune at the dyno. I going to raise the idle. AFR should get closer to 14.7
Old Aug 1, 2015 | 10:52 AM
TurboA32's Avatar
Are you going to buy the license with the nistune
Old Aug 1, 2015 | 07:11 PM
TonyJr's Avatar
No. Kings Performance is 5 miles from my house. They tune nistune
Old Aug 2, 2015 | 03:49 AM
Hectic's Avatar
Nistune's prices are a joke. Their board costs about $2 to make, their software was developed ages ago, and their prices are still ridiculous. You might want to look at other options.
Old Aug 2, 2015 | 05:57 AM
James92SE's Avatar
Other options like what?
Old Aug 2, 2015 | 08:14 AM
TurboA32's Avatar
For the price of nistune and its capabilities compared to other tuning options nistune is the best option.
Old Aug 2, 2015 | 10:42 AM
James92SE's Avatar
Tony is going to have Nistune AND be tuned for $600 total. Can't beat that IMO
Old Aug 2, 2015 | 02:01 PM
TonyJr's Avatar
A iphone cost $24 dollars to make. Lol people still buy it.
Nistune is by far the best you can get other then full standalone . I decided not to get cable or license since I have king performance 5 miles away. I talk to Chris who tunes nistune and he said that they have the record for most hp on nistune. They send a video to nistune Australia for proof. So I'm in good hands.
Old Aug 2, 2015 | 02:18 PM
TurboA32's Avatar
How much is king performance going to charge you?
Old Aug 2, 2015 | 05:45 PM
TonyJr's Avatar
$295 for the tune
$320 for chip n install
Old Aug 2, 2015 | 05:47 PM
TonyJr's Avatar
Aluminized Heat Sheath High Temperature Exhaust Heat Shield 2" x 36" Long Sleeve | eBay
I bought some today at auto parts store. For oil feed line. Need one more for wideband
Old Aug 3, 2015 | 08:17 AM
TurboA32's Avatar
$295 for the tune
If you have a laptop you can get the consult cable and buy the license for that price of the $295 and do things yourself because all they gonna do is burn a base image of your stock ecu on to the board before they installed it into your ecu then load a 300zx map on to the board then send you on your way....but then again if your not comfortable with this kind of stuff forget about it lol
Old Aug 3, 2015 | 08:28 AM
TonyJr's Avatar
Damn that's wrong if they do that. Smh. now you got me thinking
Old Aug 3, 2015 | 08:36 AM
TurboA32's Avatar
Its not really wrong, there's many people who don't know anything about tuning and don't like to mess with it
Old Aug 3, 2015 | 08:47 AM
TurboA32's Avatar
I don't know what they have at the auto parts store but the link I posted that stuff has heat wrap on one side and the aluminized stuff on the other and I don't know if the auto parts store is like this but let me know
Old Aug 3, 2015 | 09:03 AM
TurboA32's Avatar
When they do the board install for you make sure you clear any ecu codes thats stored in your ecu before they get it because if they download the base image from your ecu (which would be the correct way to do it) and theres any codes in that ecu, when they burn that image onto the board that code will always be there and the only way to get rid of that code is to put the ecu back to stock, erase the code and download the image with no codes from the ecu and ect....so just make sure you clear any codes before you give your ecu to them
Old Aug 3, 2015 | 09:04 AM
TonyJr's Avatar
It's exactly like your. What fmu ratio did you get. 8:1, 10:1, 12:1
Old Aug 3, 2015 | 09:12 AM
TurboA32's Avatar
You dont need to use an fmu
Old Aug 3, 2015 | 09:14 AM
TurboA32's Avatar
Are you using the stock fuel pump or do you have a walbro or different kind of high flow fuel pump?
Old Aug 3, 2015 | 09:59 AM
James92SE's Avatar
Where are you getting this from?
His $295 price is an actual dyno tune. Not a "bench" tune. I don't think they could do that anyway even if they wanted to. How would the 300zx maps even run his car even remotely properly?
This doesn't sound right either.
If you send them an ECU with a code in it, yes that code will still exist once you get the ECU back, but it's not like you can't just instantly clear it. That code isn't "burned" forever into your ECU.
Besides, Nistune has repositories of stock maps that you can burn to your ECU any time, and it's totally irrelevant whether or not the ECU you sent them has a code.
Maybe the 4th gen Nistune stuff is different. We (we being VE guys) have type 3 boards.
Old Aug 3, 2015 | 12:27 PM
TurboA32's Avatar
Where am I getting this from.....well you can get the license for 200AUD and the consult cable for 95AUD from nistune (us dollar will less depending on the day dollar goes up and down) and you can load any map from the rom pack if you don't know how to read the nistune instructions it tells you to copy and paste. And the car will run just fine......as far as "this doesn't sound right either" I know from experience this happen when I sent my ecu to Australia and they "Bench tested " my ecu as they dont have an actual car and made codes appear in the ecu then they download it and burn it into the board with what ever code (in my case I have 2 nistune ecu's they did this to 1 with a cam sensor code and the other ecu has 15 codes that pop up everything I connect to the nistune consult and my 3rd nistune ecu they did correctly) yes I 3 nistune ecu's lol...so when I had a cam sensor code and the car was running just fine I knew when I erased the code and the light came right back on it was what he did then matt confirmed that yea it was his bench testing the ecu that made the code appear. And the code will stay there forever if you do what I mentioned so instead of sending the ecu back I just purchased the base image programmer and did things myself and now my ecu's are code free
Old Aug 3, 2015 | 01:07 PM
James92SE's Avatar
Yes I know about the license and consult cable, I have them both. But you're telling me that if I load a K24 map to my ECU my car will run fine? There's no way, zero chance. The VE and the Z32 are fairly similar, but I would be shocked if the Z32 map(s) loaded into the VE even allowed the car to run.
Either way, this aspect of the convo is totally moot. Tony is getting an actual dyno tune from them.
This must be different from our boards. Remember the 3rd gens aren't OBD2. I can clear any codes I have right from the main Nistune window.
The ECU I sent in had a knock sensor code when I sent it off. That code didn't stay stuck in my ECU or anything.
Old Aug 3, 2015 | 02:10 PM
TurboA32's Avatar
You asked me where im getting this from so I told you but I guess you already knew the answer to the question you asked...and yes you can load what ever map you want......I loaded a 300zx map on my 4th gen with no problems and they are nothing similar right...and getting a dyno tune is defeating the purpose of the nistune...the capability of the nistune but i guess if you dont know how to use nistune consult then going to someone for a dyno tune is the only option...if i was the guy that tony is taking the car to I would just load a 300zx tune to his board since he will be running (370cc injectors z32 maf) put the car on the dyno tell him his horse power, collect my money and send him on his way...same thing jwt does....you tell them the injector and maf your running..send them your ecu...they put a 300zx map on it and call it a day
