bad idle and misfire
So all of the sudden after the car running great and timing set all of a sudden during a hot week last week the car has started running rough though i don't really think it's temp. related being it's still idling rough when cool. Im kind of stumped at this point but still need to do a little more digging. New coil, wires, plugs, cap and rotor. Injectors to my knowledge are fine. I've pulled all the plug wires etc. one by one and each change the idle. Fairly new vacume lines and had a vacume pressure test done. No vacume leaks. I've done a diagnostic on the ecu in mode 3 and no codes just 55 all normal. Im starting to wonder if it's something electrical but otherwise all sensors and harnesses are conected. Kind of strange this just came up out of the blue with no symptoms before hand. Though one day last week i did notice a very minimal oil leak that appeared to be a cam seal but strangely no leak for a week so far after that day which is weird. Any suggestions? It's a VG by the way.
You specifically mentioned that the timing was set. Why?
Has it stayed running that way, or does it only do this periodically?
My 3rd gen VG Maxima will occasionally have 1 injector act wonky on the really hot days of summer. About the time I start to think about replacing it the injector begins functioning normally and stays that way for another year.
Is your weather stripped near the firewall at the top still secure? I get issues when mine is not secured and it rains. Did it rain recently?
Cam seal leak is probably not related and it sounds like you ruled out vacuum issues.
Did you change anything else real recently? Usually when something starts going wrong I ask myself: what is the last thing I changed?
I've had a number of electrical issues that have arisen in the last year. They all stem from the deterioration of everything rubber.
It could be that some electrical bit got old and crumbly.
It's been an interesting year for my 3rd gen. I've been replacing lots of seals, vacuum tubes, and electrical connectors. It feels like all of the dang rubber pieces got together and decided to go on strike!
jmlee44
Oct 2, 2022 02:13 PM
Unclejunebug
Apr 2, 2016 05:42 AM
