Strange wine from motor under load
Old Feb 4, 2016 | 11:34 PM
serafanas's Avatar
Hi guys,
what may be the reason behind this whine from 4k RPM?
1994 auto trans VG maxima from Germany. Noise is only appearing under load. No whine when reving in neutral.
Old Feb 5, 2016 | 05:51 PM
oldpuck81's Avatar
Alternator? Timing belt? pulley? Transmission?
Old Feb 6, 2016 | 05:18 AM
Hectic's Avatar
Unfortunately, it could be anything. Seems like it is responding to vibration at a certain frequency. Could be mechanical, could be items inside the cabin rattling against each other.
Old Feb 7, 2016 | 07:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
supercharger/turbo winding up?
if it's only under load (driving) it's very possible it's transmission related.
alternator and etc you would probably hear it revving at idle.
Old Feb 8, 2016 | 12:08 AM
serafanas's Avatar
No turbo/supercharger is present
Sound is clearly coming from passenger side, so I ruled out the transmission.
I also hear strange sound under the rear valve cover, but as far as I know the valves are hydraulically lifted. Maybe that is the reason? Valves emit those sounds even reving in neutral. It is not a whiny sound, but it is not as smooth sound as from under the front valve cover. What should I do about that sound? Seems that under load and at 4k+ RPM that valve sound changes to the whine from video. Do I have a bigger problem?
Old Feb 8, 2016 | 04:50 AM
Lord Business's Avatar
"Strange wine from motor under load"
is it the taste? was it a bad year?
maybe stored improperly??
"No wine when reving in neutral"
i would advise this, as it is unsafe to operate a motor vehicle while consuming alcohol
gerardamorris
Feb 5, 2016 01:11 PM
george__
Jan 13, 2016 07:26 PM
Kcashhx
Jan 12, 2016 03:38 AM
YoloDoucheBagA33
Jan 7, 2016 11:37 AM
Calico
Jan 6, 2016 12:01 PM
