relays
Old Jan 28, 2002 | 05:59 PM
tmnismo91's Avatar
relays
does anyone know what type and amperage relays i need to build a wiring harness for my '91?
Old Jan 28, 2002 | 08:24 PM
John van de Pol's Avatar
A wiring harness for what?
If it is for high wattage headlighs, 2 x 100 watt = 200 watt or 16-some-odd amps. Most relays will handle 20A, many will do more. For switching "on" functionality, you will want a relay with "NO" or "normally open" contacts. You can get them in electronics stores for around a buck on sale, 2-3 dollars normal price. The pre-wired sockets can be had for about a buck too, but you will find the leads are not very heavy duty. Better to solder (or crimp if you must) some spade connectors onto your wires and slide them onto the relays. Most automotive relays have a mounting bracket that makes it easy to affix to a body panel somewhere.
Good luck,
John
Old Jan 29, 2002 | 02:33 PM
tmnismo91's Avatar
Re: Relays
Thank you for that information John. I should have no problems doing this mod after all. It is for my PIAA Superwhites 45/65. I learned a lesson about higher wattage bulbs. I am getting new headlight housings for my '91 here directly. The reflective coating inside my current housings is deteriorating. I also thought I owed it to myself to beef up the headlight wiring considering they're 11 yrs. old and puny to begin with. So I hope that by upgrading the wiring and installing new housings I will get more light on the road. I find it difficult to get help from people on the org. Again, thanks.
Old Jan 29, 2002 | 07:09 PM
DanNY's Avatar
Ad·min·is·tra·tor
for me..
30A low beam
40A high beam
AaronL
Nov 15, 2020 11:52 AM
zmcneely13
Sep 26, 2015 02:26 PM
Bluenissan
Sep 20, 2015 08:54 PM
BrandonCause
Sep 14, 2015 10:41 PM
