Clear corners on all the time?
check out the FAQ post at the top and read all those pages, lots of good info on there
including a certain page which has the rewire you're looking for:
http://www.prism.gatech.edu/~gte671n/mymax.html
in the how-to section
good luck and welcome
Re: Clear corners on all the time?
Originally posted by probmxstyle
I have heard that there is a way to make the corner lights light up all the time not when you use your turn signal. Can anyone help! Thanks
Re: Re: Clear corners on all the time?
Originally posted by noleafclover
well we all seem to wanna be nice to you, so oh well, no flaming today. anyway, there is a nice little feature on these forums called search. up there at the top right. anyway, you can narrow it down pretty much any way you like. and you can pretty much assume most topics like this have been discussed. thank you. and welcome!
Re: really?
well the stock bulbs have 2 terminals on the bottom of them, and the hyperwhite onrs only had one. when I first did it only one of the lights stayed on so when I check it and played with it a bit I found that when the single terminal is touching the 2 metal pieces in the bulb socket it made the light stay on all the time.
I have found that it is not the greatest idea to run both terminals on 1157 bulbs in the corners. I found that the inside of my corners have already started to melt through the plastic. I think Im going to unwire the corners or use an 1156 bulb.
Matt93SE
Apr 8, 2018 09:23 AM
griffins98max
Aug 30, 2015 10:23 PM
yat70458
Aug 3, 2015 01:16 PM
