I'm new here .
Old Dec 14, 2016 | 10:13 PM
Leonard Logan's Avatar
I'm new here .
My 1994 3rd generation maxims DiD a number on me. Lol I was traveling in my neighborhood and I cam to a stop sign, then I started to go through the stop and I heard a whip sound and my transmission quit pulling. Can n e one tell me what in the wide world sports went on?
Old Dec 15, 2016 | 07:46 AM
James92SE's Avatar
2 VE's are better than one!
Your autotragic transmission went out
Old Dec 18, 2016 | 03:00 AM
maximagician's Avatar
you mean it quit pulling at all/ wont engage any gear?
or its slipping (rpms going up and down)before going into gear?
Old Dec 18, 2016 | 04:39 AM
Yep want do n e thing.
Old Dec 18, 2016 | 04:42 AM
Fluid is not burnt clean. . I dnt get it the last ones slipped like a big dog this one just busted a col corners and then whip and quit pulling?? Lolll throwed me for a Big loopy loop! It sounds lit wants to go.in the gears but want doit.
Old Dec 18, 2016 | 08:00 PM
ac max 92's Avatar
The planetary pins letting go and dropping down into the planetaries are apparently one of the biggest problems for blowing up these auto RE4F02A's If you can find a good shop that knows how to rebuid them then thats your best bet otherwise you roll the dice on another used one or do a 5 spd swap.
Old Dec 19, 2016 | 05:55 AM
DanNY's Avatar
Ad·min·is·tra·tor
is the fluid low?
Old Jan 13, 2017 | 06:37 AM
try listening to the bellhousing area with the motor running THEN
after someone ELSE turns the key off ,the motor quits spinning almost instantly
if you hear scrape noises gradually getting quieter it is the torque converter still spinning around chewed up converter blade spline teeth
the converter blade fans splines teeth strip out
which is much better than the shaft side stripping
I had to swap a torque converter on my ex gals 90 stanza and my old 92 gxe maxima
years ago after the stanza was getting on the freeway and at kickdown it just felt like it was stuck in neutral the guy at seattle northend transmission clued me in
he said and i qoute"90's nissans are the KING of conveter failure"
after i removed the stanza transmission and draining the sus torque conveter and looking in with a flashlight it was obvious he was the master
then when it happened to my 92 gxe(kickdown going up a hill) the guy at best auto repair bothell who sold me the 'lifetime"exchange transmission plus install told me the torque converter is not considered part of the transmission,
so he knew too just by the symptom
so i had to fix the 92 gxe maxima torque converter as well
maybe previous owners did neutral drops/burnouts racing,I never really thrashed on my gxe maxima and dont think my ex slammed around her stanza
the vg30 and the ka24 fury cannot be contained
havent ran into anymore which makes me think its from hard drivin
AND I have been saying this here a few times in the last too many years
Old Feb 28, 2017 | 03:56 PM
FanaticMadMax's Avatar
wow that interesting read, I hope you end up getting the transmission repaired.
