Catalytic converter
Old Feb 12, 2017 | 02:13 PM
That_93maxima's Avatar
Catalytic converter
When i got my car the flex pipe was completely torn and i finally got tired of it and replaced the front part of the exhaust that has the flex pipe but shen i took the old ond off i found out someone had previously welded it to the catalytic converter so i took the restof the exhaust off and tried to remove the catalytic converter and ended up rounding off the rear bolts so i cut it off does anyone know if there is a direct replacement cat for our cars or if one off a newer maxima would fit because i found a test pipe for a 95 cheap and it looks like it would fit but im not sure
Old Feb 13, 2017 | 12:47 AM
maximagician's Avatar
look for magnaflow direct fit hi flow(has flanges)maybe warpspeed sells them still?
Old Feb 13, 2017 | 05:49 AM
the reason i was asking is because the test pipe is a lot cheaper and i dont have emissions testing and it has the same flanges but i dont know if it is the right length its for a 4th gen
http://www.ebay.com/itm/like/181883284431?lpid=82&chn=ps&ul_ref=http%253A%252F% 252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp% 253D164965185820_324272%2526itemid%253D18188328443 1%2526targetid%253D271413297750%2526rpc%253D0.10%2 526rpc_upld_id%253D101703%2526device%253Dm%2526mpr e%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252F ulk%25252Fitm%25252Flike%25252F181883284431%25253F lpid%25253D82%252526chn%25253Dps%2526adtype%253Dpl a%2526googleloc%253D9009565%2526poi%253D%2526campa ignid%253D714751104%2526adgroupid%253D42866488452% 2526rlsatarget%253Dpla-271413297750%2526gclid%253DCjwKEAiAz4XFBRCW87vj6-28uFMSJAAHeGZbK9X-PAiCDyjxrTL0eHOqc-tsSqb2VgnU5pOYsQw7QBoCXZ3w_wcB%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1167537528481&ul_noapp=true
Old Feb 13, 2017 | 06:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
the 4th gen test pipe MAY fit...but it's a chance you have to take.
if you don't want to run a cat then i'm sure a local exhaust place can weld you something up for under a 100 bucks.
if you want the cat on there there's plenty of aftermarket solutions available.
Old Feb 13, 2017 | 06:22 AM
the reason im thinking about a getting a test pipe is because its cheaper than a new cat and im trying to stay away from an exhaust shop because they are the reason i have to replace the cat it was previously taken to an exhaust shop and they welded the front section of the exhaust to the catalytic converter
Old Feb 13, 2017 | 01:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
getting it fixed and getting it fixed correctly are totally different things.
why the exhaust shop just welded it? because the owner didn't want to spend the time to get flanges and getting it fixed right. the stock flanges were probably totally trashed.
if you don't want to go to a shop then you'll better start learning how to weld.
you'll need a piece of pipe and 2 flanges that will mate up to the y-pipe and the b-pipe. once you have that you'll need to weld the flanges or at least have the ends of the pipes swaged so it creates a lip so the flange won't fall off.
Old Feb 13, 2017 | 03:54 PM
they replaced the cat then welded the bolts on it so it cant be removed and i might just cut the bolts then redrill the holes out and get new hardware or i found a cat on craigslist from a 240sx for $20 and it looks exactly like the one i took off my car
jsmith24
Feb 24, 2017 10:17 AM
